Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
The tray wont dump automaticaly I have to push the reset button on the bottom of the tray to get it to dump
  • 2 more comments
  • blackhd1 Apr 25, 2010
    The Ice tray
    RS2530BBP
    Its not doing that either. Whats with the word games? Is not working.
    No it has the ice in the tray it just will not roll the tray to drop the ice by itself, But thanks for your time and efforts.
  • 4,889 Answers
What tray are you talking about? The tray that dumps the water collected during defrosting among other things?
Posted on Apr 25, 2010
  • 1 more comment
  • eagle338
    eagle338 Apr 25, 2010
    Can I have the exact model number of the refrigerator please?
  • eagle338
    Page 7 of your refrigirator's manual says that Ice can be dispensed only by pushing the button. It only automatically makes 120 cubes a day not automatically dispense them.
    Click here to view the manual
  • eagle338
    In that case you probably have a clog in the Ice dispenser. Do you at least have water coming out of it which may suggest a thermostat failure? You may find this article helpful.
    http://www.ehow.com/how_112158_repair-cl...
    If its not clogged water supply you should take the assistance of a qualified refrigerator tech to get it fixed. You can use our repair directory to locate one in your area.
    http://www.fixya.com/repair
    Sai.
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Ice made but will not dump.
Hello, There is a heater in the bottom of the tray where the ice cubes are formed. The heater melts the bottom of the ice cubes just enough to release the ice cubes from the mold. I suspect your mold heater is not working.
Oct 13, 2015 | Refrigerators
Ice wont dump
it is not cycling , put hot water in it and melt what is in therecompletly out and try to reset it that way watch the mess , be carful trying to chop it out do not break anything
Mar 28, 2014 | Whirlpool GS6NBEXR Side by Side...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Lfx25976st
Could be an open circuit to the ice tray sensor. This is the wire under the ice tray. It is flexed during each cycle and can fatigue easily. I found this condition on a three year old unit. A simple solder repair and heat shrink tube corrected the problem.
Jul 26, 2012 | LG LFX25971ST Bottom Freezer French Door...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
Water won't pump to the ice maker.
No button to push. It sounds like the solenoid valve which opens to fill the ice tray is not working. Not getting power, stuck, faulty.
May 08, 2009 | Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
