Question about JBL GTO 1201.1II Subwoofer Mono Amp - 800W Grand Touring Series Class D 1100 Watts @ 2 ohms Car Audio Amplifier
I need someone to repair a soundstream Rubicon 702
  • 344 Answers
What area do you live
Posted on Apr 26, 2010
I've had two soundstream rubicon 1.1600D amp's and they both worked for a while then the amp started to kick off and on. No fuses were blown, and the ground was fine. Any suggestions would be appreciated.
Sounds like a loose power connection? Check All connections, also make sure the impedance is correct 4ohm 8omh 16 ohm the speakers need to match the amplifiers output to work properly. ...
Feb 21, 2015 | Soundstream Car Audio & Video
What size fuse do i use in my amp
I would highly replacing it with an identical one.
What is the question? More information is needed before somebody can help you.
May 12, 2014 | Soundstream RUB1.700 700 watt 1 channel...
Why would my 2500 soundstream Rub1 amp keep going into protection mode
Take a look inside it could possibly be a/some capacitor/s. If it is replace more than just one because they can also be going bad. This is a cheap fix they cost less than one or two dollars a piece.(if this is the problem)
Mar 30, 2014 | Soundstream RUB1.2500D 2500 Watts RMS Mono...
On the Soundstream Rubicon 5 1/4 speakers there is one large connector and one small one, which is which? positive and negative?
The smaller terminal is most often the negative terminal. This link has a great way to test if you are unsure.
http://www.techguys.ca/howto/speaker.html
Mar 17, 2014 | Soundstream PCS-12 Car Subwoofer
Soundstream pca2000d started smoking on me what do you think is wrong
well. if it doesn't function after smoking, then it needs to go to a GOOD technician. ( if one is available to you) if not then send it to soundstream. if this was not a good amp , I would advise getting rid of an amp that smoked, however soundstream is a good brand and deserves another chance. (always depending on the cost of repairs)
hope this helps.
.......andy.......
Dec 29, 2013 | Soundstream PCA2000D Car Amp
Power to rubicon 404 no sound 4 channels of 2-way high pass
Check RCA,s at the back of the head deck, make sure sub is set to low bass frequency, make sure gain is turned up on the amp and head deck has subwoofer enabled and bass on. If you are powering speakers make sure the balance on the head deck is set to 0. Make sure it's wired up properly.
Jul 22, 2009 | Soundstream XTA240.2 Car Audio Amplifier
5 BLINKS
My first guess is IC 702 in the crt drive circuit. You could open the back and unplug the "C" board from the back of the crt and then power it on. If the set comes up and you have good audio that will isolate the problem.
If IC 702 is the problem you'll have a couple of other things to check, R533 .47ohm 1/4 watt fusible resistor and C541 22uf 100v both on the "A" board because they tend to stress when IC 702 begins to leak. Replacing IC 702 and not the resistor and cap could cause 702 to fail again.
If IC 702 is not the problem then it could be the flyback.
Hope this helps!
Bill
Nov 05, 2007 | Sony KV-28FX60 28" TV
JBL GTO 1201.1II Subwoofer Mono Amp - 800W Grand Touring Series Class D 1100 Watts @ 2 ohms Car Audio Amplifier Logo
91 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
