Question about SharpVision XV-DW100U Multimedia Projector
Sync issues with Direct TV HD recievers
I can only interconnect my Sharp vision projector using RGB connections and the resolution that I can recieve is only 480 P. Anything above that does not sync and the picture flashes in and out. All the new HD recievers use HDMI and this projector only has VGA, RGB or five line interconnectivity. Is it new projector time or is there something I can do to make this projector work with native formats of 720P or 1080I?
  • 563 Answers
Hi Michello
I'm afraid it is indeed new Projector time.
Posted on Mar 26, 2008
How do I change the screen resolution on the TV from "standard 420" to HD?
The screen resolution will automatically change based upon the resolution of the input signal.
Are you using an RCA connector? Perhaps an S-Video connector? NEITHER OF THESE ARE CAPABLE OF PRODUCING HD VIDEO!!!
In order to view HD video, you must use one of the following:
  1. HDMI connector (optimal)
  2. DVI connector (almost as good but requires a separate audio connection)
  3. RGB video connector (also requires a separate audio connection)
If you are using one of the three connection types above, contact your DirecTV representative to find out how to switch your cable box output from SD to HD.
Jul 20, 2014 | Vizio 42"" vw42lhdtv10a 720p widescreen...
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
How do I connect a Sony KDL55EX620 HD TV to a stereo receiver. I am using the HDMI cable from a DirectTV receiver. How do I get the audio to my stereo?
the audio comes out of the Direct TV reciever, OR Audio OUT on the television. Some TVs that take the signal HDMI, do not put sound back out, and in that case, sound signal must come from the reciever box.
Each component, like DVD of Blu Ray will need to have a signal wired to the stereo unit.
Apr 27, 2011 | Sony KDL55EX500 55 in. HD-Ready TV
I need access to manual for the Image Pro 8758. We are getting no picture output from Projector. currently using the component to 15pin VGA wiring. Which is connected to the Computer 2 input terminial on...
Try pushing the source button either on the projector or the remote. It will tell the projector to look for another source. It may currently be set on one of the other sources. If you look up the manufacturer on-line, you should be able to download the manual.
Jan 13, 2011 | Dukane ImagePro 8755A Multimedia Projector
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Just got 46" lcd sharp tv with hd dvr dish reciever on display it shows it has 480p how do i get 1080P
If your dish receiver can receive 1080p then you will get it, if it doesn't then probably the most is 720p/1080i. Check the dish resolution.
Dec 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
Sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Jun 20, 2008 | Televison & Video
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
SharpVision XV-DW100U Multimedia Projector Logo
170 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
