Question about Nesa Vision NSC-320TM 12'' Overhead Monitor
The screen want come on,the machine will eject lights will come on ???? thanks Jim
  • 175 Answers
Could have a power problem but need more infi,
Posted on Apr 27, 2010
Testimonial: "i did think this could be the possible problem,because the rear window,will not work,or the wiper or washer,thank you so much. jim"
Technika aedvdrhdds7 dvd stuck
Hello
You have to open the player's top cover, and must rotate the gear wheel at its loading tray to get the CD out.
Feb 27, 2012 | Televison & Video
Jim Thompson: There is no eject button on my eMac so it didn't work to tilt the computer. What now?.
I have a couple solutions for you
1)Check the upper right corner of your keyboard for an eject button
2)Press and hold the F12 key, may take several seconds
3)There should be an icon on your desktop of the CD simply drag and drop it to the trash can
Please notify me if this solution worked for you.
Thank You!
Dec 21, 2011 | Computers & Internet
Hi - we have a Roberts MP53 DAB radio. When finished playing the cd we press eject with either the remote or on the unit and although it says eject on the screen it doesn't. After about 10 secs the visual...
Mine did the same at first. I turned mine upside down and pressed eject and that worked to get the CD out then let it warm up to room temp and all is well.
Jan 16, 2010 | Electronics - Others
Self check for over an hour
While the unit is switched off, Jim, press and hold the STOP and Channel Up buttons (BLACK SQUARE and CH/\) on the unit (NOT the remote) for 5-10 seconds and your disk should eject.
Apr 16, 2009 | Panasonic DMR-ES10 DVD Recorder
Toshiba P-30 Screen Problem
Well Jim, this could be a couple of things, a simple driver glitch, or a dead pixel area. Let's hope for the driver glitch. Start by uninstalling the video drivers from the device manager, then reboot. The machine will find the screen and reinstall the video drivers. Then readjust the screen resolution in the display properties. If the problem persists, then I'm afraid you have a dead pixel area. This will be caused due to a bad screen inverter or bad screen, then the inverter or screen will have to be replaced. It's very rare, but occasionally a loose or bad connector can cause this. You might also check the screen connections for a loose connection or a little dirt/corrrosion build up.
Jul 20, 2008 | Toshiba Satellite P30 P35 Series Notebook
Set the eject tray
is there a job seperator on this machine (gray tray in middle of paper eject)? If so try this...Press */language key @ left of control panel...Scroll down to "Machine default", press enter key...enter code 2000 or 6482...scroll to ejector of fax (if equipped) or ejector of copy...select what tray ...scroll up to "end"...press enter...that should bounce you back to "Ready to copy" screen.
Jul 06, 2008 | Copystar CS-2030 Copier
How to correct or rotate e-machine monitor screen view
Jim,
  • Press and hold Ctr + Alt then press Up arrow
  • (i.e. Crt+Alt+Up arrow)
Thanks
Iqbal
May 17, 2008 | E-Machines eMachines Monitor E15T4
DVD caught inside machine
When a DVD won't eject, the most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the DVD. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) try to find the motor and belt which operates the DVD loading & eject mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the DVD is why you may not have this problem during a load sequence.
Let me know what you find and we'll go from there.
Good luck,
- Jim
Feb 15, 2008 | Philips DVDR985 DVD Recorder
Daewoo DVRS04 DVD Recorder
problem is on your power board,replace elco on +5v ,-5v 12v, 24v
Nov 28, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Car Audio & Video Logo
223 people viewed this question
Top Nesa Vision Car Audio & Video Experts
xxxxxx xxx
Are you a Nesa Vision Car Audio and Video Expert? Answer questions, earn points and help others
