Question about Kenmore Elite 45986 Front Load Washer
I have a old kenmore top load washer I took apart to unsieze the motor. I was wondering what the four plastic cups with nails in them are for? Are they supposed to be pushed up and they drop down when the washer is not balanced?
    Scholar:
  • 126 Answers
THEY ARE THE SHIPPING PINS THAT FALL INTO THE CUPS AFTER THE STRAPS ARE REMOVED WHEN DELVERED. KEEP THEM THERE OR THROW THEM AWAY. THEY ALREADY SERVED THEIR PURPOSE.
Posted on Apr 25, 2010
Stopped agitating
Its probably what they call "dog ears". My washer was doing the same i took off the cap on top of the agitator and un screwed the bolt. I grabbed that white piece out and there were four little plastic pieces that looked like dog ears and i replace them for under 1.00 and mine was fine after that.
Aug 25, 2011 | Kenmore 22422 Top Load Washer
Product = model 15962 Problem = really bad smell
A good trick that i found was to fill tub with hot water and put a full cup of dishwasher detergent any kind but has to be powdered not liquid detergent. Do this two times in a row and then every month.
Jun 10, 2011 | Kenmore 15962 / 15964 Top Load Washer
Spins , but not fast enough to get water out of clothes.
I had exactly the same probelm on my four year old Roper. I took the clutch apart and it had some foreign material on the white plastic clutch surface. I cleaned it up with fine sand paper and also used some emery cloth on the stainless steel "cup" that the clutch bears on. To increase the tension on the spring I added a couple of washers at each end. The washer now spins just like new. If your clutch is really warn out - down to the rivet surface you can get a new one for about $40 from most appliance repair shops
Jan 07, 2010 | Roper RAX4233PQ Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite washing machine. it is not spining the clothes all the way. it is leaving the clothes soaking wet.what should i look at
Take the agitator apart by pulling off the softener cup and taking out the bolt, probably broken plastic DOGS. Ask your appliance parts guy for them.
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 70 series washer
your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Plese help
Its hard to diagnose these motor problems...takes a volt-ohm meter with a capacitor checker.... and a lot of knowledge if youre up to it, ill try to help.
Jan 24, 2008 | Kenmore 22422 Top Load Washer
Washer repair
The pins are supposed to fall out thats why there are plastic catch cups. Its designed for shipping with the pins put back your washer will not work properly and may damage it if continue to use it with the pins.
Dec 02, 2006 | Kenmore 20172 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
