Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
1985 40hp evinrude only runs at half speed - Light Outboard Motor Boat Bass Fishing Saltwater Base
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Light Master
  • 1,190 Answers
Check the carb/s opening full throttle when you throttle up to max on the tiller or remotes pending what your using ! is carb clean and ignition set correct ? compressions good etc ? sparks on all cylinders ? multi carbs balanced ?
Posted on May 30, 2014
    Top Expert:
  • Light Master
  • 43,127 Answers
It might be as simple as a dirty carb , but also might be in the ignition ,like a bad power supply module . check for spark on but plugs .
Posted on Apr 25, 2010
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Evinrude 30 hp
there shoulld be an idle adjustment screw on the carb.
Jun 11, 2014 | Boating
9.9 evinrude, yr 1990..runs like a new motor but wont throttle up past about half speed..once or twice it kicked in and took off but only for a few minutes then went back to half speed..sometimes it will...
Check the fuel tank for water.Squeeze the fuel line bulb and see if that gives a boost,and if it does you may have a blockage in the tank or in the carbs.If the bulb contracts when the engine is running,you have a blocked pickup in the tank.Check the vent on the tank is not blocked.The symptoms you give all lead to a fuel problem.Also.Check to plugs after you have run the motor.If one looks darker than the other.Change them both.Hope some of this may help you
Sep 02, 2010 | Light Outboard Motor Boat Bass Fishing...
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
Have 90 hp evinrude 1982 What rpms should it be running on idle?
You can get rpm data by searching your browser using "90hp Evinrude Specs" or "1982 90hp Evinrude idle specs". Changing the jets usually costs you performance on one end or the other. If you have needle rods, a narrower one will have the same effect as a bigger opening in a jet. But you have rpm limits that you should not exceed. Changing the prop can give you more power over the sacrifice of top end speed.
Jun 13, 2009 | Boating
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
509 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
