Question about Husqvarna Zero Turn Mower Z5426
New motor when i put blades on the motor drop's rpms then pick' back up not sure 25 hp kohler
  • 4 Answers
When the engine has more strain add to its work load it will automatically adjust and bring the revs up to meet the new demand on the engine , hence the drop and then rise in revs
Posted on Apr 25, 2010
I have a Kohler 7.3 ECD generator with error code UVunder frequency. Restarted gen and it ran for one hour so I shut it off. What's the problem?
check the operating rpms
the rpms determine the voltage and frequency and can be adjusted at the governor spring setting
adjust it until the voltmeter reads the required voltage
set slightly above to allow for rpms drop under load
for example if 240 volts set around 250 volts and that will drop back to 240 volts under load
if 110 set around 115 and that will drop back under full load
both frequency and volts are dependant on rpms
Sep 20, 2016 | Kohler Electrical Supplies
Why does a craftsman tracor with a kohler 15.5 hp engine bogg down when engaging blades
It will initially bog down when engaging, but should pick back up shortly after. If it is staying bogged down, turn mower off and check inside (under) the deck to make sure its not clogged up with grass clippings or dirt. if it is, clean it with either a hose or a scraper. Also make sure the deck is raised when you engage (dont engage with deck lowered on long grass).
Jun 15, 2014 | Craftsman Garden
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
1996 Ford 300 six cylinder loses oil pressure when engine warms up
first you will have to say what the oil pressure is cold, idle and 2000 rpms and then hot idle and 2000 rpms before a decision to advise about a rebuild can be made
there are many reasons oil pressure can drop and not all require a rebuild
May 26, 2017 | Ford F-150 Cars & Trucks
Necesito manual tecnico para la reparacion de un motor kohler de 20 hp y de 25 hp. por favor me es muy urgete . SI ES POSIBLE EN ESPAÃ?OL MUY AGRADECIDO POR SU APOYO
No hay ningun manual en espanol para este motor CH730..segun su sitio web. Encontr? este manual en ingles..Por favor p?ngase en contacto por el servicio al cliente a ver si lo tienen en espanol (Kohler Engines). http://www.kohlerengines.com/onlinecatalog/pdf/tp_2428_b.pdf
Nov 12, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have a powermatic table saw, 7 years old with a 2 hp baldor motor and when i start it the motor hums but the blade just shakes back and forth. I can turn the blade by hand and rotate the motor fan...
You may have lost power on one of the wires to the motor. Check the wiring for breaks, if you have a meter make sure there is power to the 2 110 volt wires.
Jan 09, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Zero Turn Mower Z5426 Logo
118 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
