Question about LG LHT854 Theater System
Need to reset its on 1080p and i have no picture so i cant see the setup screen
  • 22 Answers
Run a composit cable from the unit to your tv change inputs to that and you shoud be able to see the setup
Posted on Apr 25, 2010
I don't have a picture but I have sound with my Roku Streaming Stick
I use a Roku 3 but the display setting should match the Roku setting. Hence 720 to 720. It is tough to get a 1080p picture via wireless which is the only option with the streaming stick. The distance from the streaming stick to the router could be a problem. I am assuming the setup screen displays correctly.
Dec 27, 2014 | Roku Streaming Stick
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 31, 2011 | Televison & Video
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
I have a Panasonic PT-53wx54 HDTV. The text on the ticker on the bottom of the screen that stations like CNN run is not completely visible, only the top of the letters show as they travel across the...
The set is probably in the wrong display format for the channels you are watching. Look through the setup menus for "Display format" or "Display mode". You need the menu that sets the picture for "480i", "720p", "1080p", etc. Set it for 1080p and see if that fixes it. The lower settings won't show all of the lines for a 1080p picture; they are used for old-style analog video or low-bandwidth broadcasts.
Disclaimer: this is general information and may not apply exactly to your particular model. You may still have to find your owner's manual or download a copy to find out how to correct the settings.
Oct 06, 2010 | Televison & Video
My dvd playeer was playing fine until I pressed the setup button, from there I went into the screen with 480P, 780P, 1080P Etc.. I pressed 1080P and the screen went blank and I cant even get back into the...
Try pressing the HDMI button on the remote control to toggle the display output to something that your television will recognize. You can also try The progressive button and see if that helps. I am assuming you model is the XD-E500 model.
Jan 13, 2010 | Toshiba XD-E500 DVD Player
My insignia flat screen has turned colors and bad focus. Almost like tartan plaid on top of the screen. Not an input issue, happens on all inputs
try to see if not the input but the setup on like 720p 1080i 1080p sometimes u can change the setup and it resets that happened to my westinghouse 37in
Dec 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a sylvania 1080p HDTV and can't figure out how to get it to 1080p it is at 480i ???? any help would be greatly appreciated
The signal coming from your cable box, FTA receiver, or whatever source, is usually what drives your TV's resolution. If this happens with a Scientific Atlanta HD cable box, for instance, there's a "Setup" button on the remote control that allows you to indicate how your TV interacts with the box and responds to resolution changes, depending on whether the signal is SDTV (4:3) or HDTV (16:9).
In my case, with my Sanyo 50" 1080p HDTV, I get the best of both worlds by using the setting (I forget what it's called) that gives me two "pillars", one on each side of the picture, when the latter is standard definition, and full wide screen picture when the signal is HD. These pillars are of some shade of grey, in order to activate the pixels on the side of the picture and avoid the burning of the standard, 4:3 formatted screen on my plasma pixels.
Failing that, look into your user's manual and see whether this is something you can set within the TV's configuration menu.
Last, investigate the different options offered by the TV's own Setup menu, usually available from the TV's remote control.
Aug 26, 2009 | Computers & Internet
50 inch plasma ge tv. picture is to big
You will have to go to the setup on the LG50P.... and get to the picture resolution, For example your monitor settings should have the ablitiy to set up the 4:1 or 16:9 aspect ratio. The best is to set this at automatic ... usually the case on a 1080i or 1080p
Jun 19, 2009 | LG 50PG20 50 in. Plasma HDTV
LG LHT854 Theater System Logo
370 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
