Question about Amana MVH230 Microwave Oven
Can you tell me what code F4 means? model
Can anyone tell me what code F4 means? amana radarange model mvh230
thanks
tom
  • 48 Answers
Code F4 means you need to repair the line to or replace the oven temperature sensor. The line typically runs from the display to the back of the oven, you'll have to trace it yourself. The oven sensor should be mounted to the back of the oven lining (Obviously on the inside) by two screws. Disconnect the power from the unit and unmount the sensor to check it, you should have around 1080 ohms of resistance but first you'll have to get that annoying plastic housing of wires through the mount hole and disconnect it so you don't lose it inside the oven. If you don't see screws from the inside of your oven than you'll have to remove the back panel to access them, but this may be a good thing as you don't have to worry about fiddling the plastic connector piece into the oven. You're measuring the resistance from one lead to the other inside that plastic housing, again at around 1080 ohms in a 70 degree environment. If you're way off, or 5 - 6 ohms off, you'll need to replace the sensor. If the error occurs while cooking you can also run the oven hot, turn off and disconnect the power and take your measurements again. If they read the same your wiring harness should be okay and replace the sensor.
Oh and btw, you'll most likely have to splice the wires to adapt to your new sensor they're never the same.. not in my experience lately anyway.
Posted on Apr 25, 2010
What is the symbol --se-- on a amana serial number1000001gt radarange microwave oven mean
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 16, 2013 | Amana Radarange Microwave Oven
Door handle on Amana Radarange Model MVH100E1 came dissconnected at the bottom of handle. How do I reconnect it since it appears to have been riveted to the door?
I would use epoxy glue allow it to dry 24 hours for maxium bonding, clamp it in place for best results, otherwise the door would probably need to be replaced.
May 02, 2012 | Amana Radarange Microwave Oven
I have a Amana microwave with a f-5 fault code.Model#RFS12SW2
Hi ejv3968,
This means that you have a control board failure. Error code F5 can only be fixed if the control board (ERC) is replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 05, 2011 | Amana Radarange Microwave Oven
During reheat and popcorn settings - the error code F4 appears
Hi hoodrd,
If you are encountering F4 error code from your Amana oven this is because you have an Open Oven Temperature Sensor. This error requires a replacement of new oven temperature. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 17, 2011 | Amana ACO1860 Microwave Oven
What is the code for unlocking the radarange ?
If the childproof lock has been set and you want it off, press and hold the "0" button for four seconds. You will then hear a beep-beep and your microwave is ready to use again.
Apr 05, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Nov 21, 2007 | Microwave Ovens
Microwave Ovens Logo
212 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
