Question about Sunfire Classic Vacuum Tube 2-Channel Amplifier
Loosing sound from lp
Start loosing sound from turntable gradually.First one chanel and ..Talk to sunfire they told me to replace tubes.Did that ,same thing .Did anybody knows what to do? Cd plays perfect
  • 22 Answers
Are you saying you have a problem with it keeping a continuos signal? you may need to install a pre-amp, even though you shouldnt have to.....
Posted on Apr 25, 2010
I just picked up a Zenith Solid State stereophonic portable turntable. When I turn it on it makes a humming sound. How can I fix it? The model number is NPS40. Thanks, Karen
This is a common problem for older audio equipment. It is caused by old capacitors drying out / changing values / shorting internally.
This problem can be minimized and even eliminated by a process called "forming". Forming is done by gradually applying the voltage to the device over time. You would need a piece of special equipment called an variable isolation to do this. You start at 0 volts and over the course of a day (or more) - gradually increase to 120 volts. Simply plugging the device into a 120 volt outlet defeats the forming process and once done - is irreversible - if the capacitors were the cause of the problem. The only thing left to do is to replace the capacitors; which restores the sound - but not the value of this vintage piece with new components (if that was your goal). Some technicians will install new capacitors inside the old ones to make it appear as original. You'll probably need to have this checked out by a pro.
Oct 20, 2015 | Audio Players & Recorders
No sound coming from turntable
Things to check:
1. is cart connected to arm, or are wires loose?
2. Is turntable connected to rest of system, or are wires loose?
3. Did this ever work, or is this a new connection? If new:
A. Does rest of system actually have a 'phono" input? If not, you may need a "pre-amp" to boost phono signal.
Jun 01, 2015 | Audio Players & Recorders
No right side chanel sound
reverse the phono cables to see if the other side goes out if it does you could have a bad cable or the wire is off at the catridge.
Nov 22, 2012 | Audio Technica ATLP120USB Turntable
Turntable slows down and stops
If it has a belt drive, the belt has stretched and needs to be replaced.
Oct 07, 2012 | Teac SL-A100 Turntable
Ranover something in my 1998 pontiac sunfire 4 door & besides the radiator and some bar in front of the radiator being bent in half there is a gaping hole in the bottom of some casted metal. seems...
sounds like you need a new car.
I am thinking the 'casted metal' is your engine (possibly a motor mount tore loose in the ,er... incodent).
Oct 12, 2011 | 1998 Pontiac Sunfire
The computer is coming up and saying error. we
you could have a (under the steering column) bad ignition switch.
Apr 14, 2010 | 2001 Pontiac Sunfire
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
Technics 1200MKII tonearm problem
Most of your question was missing, so I'm guessing what you were going to say.
It sounds as though one of the arm pivots - one vertical and one horizontal- has worked loose or broken. They are very delicate precision parts.
Unless you are very skilled you should leave this job to a specialist turntable dealer to fix.
Jan 22, 2009 | Technics SL-1200MK2 Turntable
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sunfire Classic Vacuum Tube 2-Channel Amplifier Logo
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
