Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Hello, Problems I am having the same problem with my 52" rear projection GE tv. My chassi# is ITC222. What can I do? Thankx
  • GE Master
  • 8,617 Answers
Can you post the problem that you are needing help with? I am somewhat famillar with this Chassis.
Posted on Mar 23, 2008
My tv dosnt turn right on it takes about 5 minutes
The CP150, CP120 and CP114 capacitors are most likely getting weak. Very common with the ITC222 chassis in both RCA and GE models.
Jun 04, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Board in back of tv all the way to left is fried. what is the board called and where do i get parts
That is called the HV deflection/power supply board. Your set was made by RCA and the chassis is a ITC222 and you won't find the complete board new. You might find a rebuilt from Tri State Module or if your going for individual parts you can go to Encompassparts.com.
Oct 24, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a 52 inch projection TV that takes several attempts to turn on. When it first started having problems, it would turn on after puching the on button about 3 times. Now you have to cycle through about...
Thats the same model as the RCA ITC222 chassis . You can get the CP150, CP114 and CP120 repair kit at www.tvrepairworld.com which should solve that issue. The kit contains the parts and the CD with instructions.
Sep 30, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Keeps shuting off.
Hello bondaddy60, I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 09, 2009 | RCA D52W19 52" Rear Projection Television
COMES ON BUT GOES BACK OFF RCA D-52W19 REAR PROJECTION
Hello ,
I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
I hope this helps,
Shuttle83
May 24, 2009 | RCA D52W19 52" Rear Projection Television
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
R52WM24
I will need you to look on the rear tag and let me know the chassis number as that model was produced with two different chassis numbers ITC222 and the ATC221 chassis was used, But the chassis number will be on the tag on the rear panel. Please reply to this same post and I will help you locate the power supply board.
Aug 13, 2008 | RCA R52WM24 52" HDTV Projection Television
Need Flyback Part Number
You need flyback number 259296 you can get a replacement at the following link for under 50.00 with free shipping
http://servicemanuals.vstore.ca/
May 20, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Apr 08, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
