Question about Hitachi 60SBX78B 60" Rear Projection Television
Wavy line goes through picture during color changes,picture cut off on bottom
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
wavy line goes through picture during color - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
I have a Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television. I do not have a remote for it, which I am going to purchase ASAP. When I press the up/down channel button on the TV it changes the...
Ur tv have a convergence problems.Ur convergence board the two convergence ICS,and some or all it resistors are dead.U know how to solders?U have soldering tools,and solders.Tries Websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 10, 2010 | Philips 60PP9202 60" Rear Projection...
Wavy picture on top and bottom
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Mar 29, 2010 | Sony KP-53HS30 53" Rear Projection...
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Televison & Video Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
