Question about Brother IntelliFax-2820 Laser Fax
New drum when I put in a new drum, how do I reset the machine, to let it know a new drum was install.
    President:
  • 405 Answers
You need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Posted on Apr 26, 2010
Reset drum counter 130f
Do not reset drum counter unless the drum has been replaced.. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
I want to reset the Brother MFC 7340 drum apparel
After you put the new drum unit and toner cartridge assembly in the machine, press Clear/Back. To confirm you are installing a new drum, press 1. When the LCD shows Accepted, close the front cover.
Dec 06, 2010 | Samsung ML-1640 Monochrome Laser Printer
MX-C311 Sharp...constantly sayd add drum. Drum has been put back into machine
When you installed the drum, was it a new drum you put in? And if so, was there a message being displayed to replace the drum? Because if so, you have to manually go into service mode and reset the drum counter.
-David.
Oct 30, 2010 | Sharp MX-M350 All-In-One Printer
New drum
It is important that you replace the drum when the machine is saying "REPLACE DRUM"...NOT when it is saying "REPLACE DRUM SOON".
When the machine says "SOON" it is advising to have a drum on-hand ready for replacement. The machine will still be able to print pages. When the machine says "RPLACE DRUM" it will no longer print and a new drum cartridge must be installed to reset the indicator.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
Brought a new drum and the machine still says error
Check the instuctions that came with the drum. You will need to reset the drum count so it knows that a new drum was installed.
Apr 19, 2010 | Brother MFC 7420 All-In-One Laser Printer
How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Oct 07, 2009 | OKI C3400n Laser Printer
DRUM LIGHT WILL NOT CLEAR
As far as I know there is no "manual" way of resetting this. The new drum has a small glass fuse which should blow when it is placed in a machine for the first time. It is the machine "seeing" this fuse blow that resets the message.
Are you using a "new" drum or one that has been in another machine?
You can try to fit a new fuse to the drum.
May 14, 2009 | Muratec F320 Plain Paper LED Fax
Reset the drum count on a brother intellifax 2800.
Drum counter is reset by installing a new drum which contains a specifically designed "starter sheet" that is passed through the machine when it is installed, and triggers the paper sensors in a specific pattern, resetting the electronic counter.
If you have installed a new drum and the message remains......I suspect that it was a remanufactured unit that did not include the "starter sheet" Is that the case?
May 03, 2009 | Brother IntelliFAX 2800 Laser Fax
Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Unpack the new drum unit.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Aug 02, 2008 | Brother IntelliFax-2820 Laser Fax
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother IntelliFax-2820 Laser Fax Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
