Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side and the refrigerator side is warm. Freezer side is working but other side is on 9 and still warm. Can this be fixed?
This is not a problem it is normal according to the manual. A pair of heat transfer pipes are installed
in the front corners of the refrigerator to
dissipate heat generated during the
refrigeration process.
Posted on Apr 25, 2010
GE side by side refrigerator not working properly. Fresh food side is warm. Freezer side is at 9 degrees. What could be the problem?
Check for ice buildup at back of freezer. If so then auto defrost mechanism is not working. Check for bad defrost timer, heater, and defrost thermostat.
Oct 17, 2015 | GE Refrigerators
Freezer is blowing warm air, it is only 32 degrees at the 9 setting. door seals are hot. Everything is defrosted.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | Hotpoint HSS25GFP Side by Side...
I have a Maytag side by side F/F. The freezer although on is not working and have had to throw all the food away. The fridge is also very warm and water has been leaking at the bottom. Not too sure...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 01, 2010 | Maytag MSD2656G Side by Side Refrigerator
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm refrigerator
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can before anything starts to thaw. Put everything back in, turn it on and this should last a couple of days.
Oct 28, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Whirlpool gold gd25df Fridge/freezer warm
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Aug 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
147 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
