Question about NetGear WGR614 Wireless Router
Set up router
When im in the set up it stops half way and says that i lost connectivity but i still have the internet light
Posted on Apr 04, 2008
SOURCE:
Router wont connect internet
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Jun 19, 2010 | NetGear RangeMax WPN824 Router
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Router connection loss
Your router might have been reset and now the settings on your devices does not match that of the router. If you have wireless security enabled on your router make sure your devices are set up to match those settings.
Jan 24, 2010 | 2wire 2700HG-B Router (2700HGB)
Wireless printer stopped printing-wireless router light flashing
Restart your Printer so that it can Look for the Connection again, if you havent done this already.
If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
Jan 14, 2009 | NetGear WGT624 Wireless Router
Linksys wrt54gs, no WAN light or signal
Press the reset button on the back press it in for 20 seconds let go and then pull out the power. Then set it up again.
DSL
Cable
Jan 07, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Router not responding at all
Refer to the instruction booklet about how to re-initialize (re-set) the router. You will then have to re-enter all the setups.
If it does not re-initialize, then it is internaly defective.
Jerry G.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
NetGear Wireless Router - continous internet connection drops
Hi sharon,
If you  upgraded the software but still the connecitons is droping then contact the ISP (the internet service provider ), Because it is possible that they have something wrong thier side,,,THIS ISSUE IS KNOWN AS INTERMITTENT SYNC OR ROUTE,,, check the lights on your router , when the internet goes down which light changes,,,
and once you confirm that the problem is not with your ISP then you need to purchase a new router,
reply which is the ISP you are subscribing for.
Gunja :-)
Oct 25, 2007 | NetGear WGR614 Wireless Router
Network
as long as you are not using your own router to connect to your neighbours, as this wont work only one router on the network can connect to the net Im assuming your pc is trying to connect to the neighbours router, so you need to reset the router if you cant access it, it should have no password as default and the ip address of the router should be 192.168.2.1. get into your network cards properties and ensure obtain an ip address automatically on the TCP/IP line is selected. Go into the router settings and make sure enable DHCP is set to allocate ip addresses automatically and that the router transmits on mixed mode b and G, turn off any wep or wpa encryption until you have a connection. Do not use windows connection repair as it will totaly mess up your pc's ip addresses and stop you from connecting to the routers ip address.
Aug 28, 2007 | Belkin (F5D72304F5D7000) Router
NetGear WGR614 Wireless Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
