Question about Onkyo TX-SR606 Receiver
Handshake problem with panasonic Viera TV
I have a problem with handshake Panasonic Viera TH50PZ850AZ and Onkyo TXSR606. My Panasonic Blu Ray DMP BD35 player is connected via a HDMI to the amp which is connected to my TV via another HDMI. This worked fine for 6 months or so but suddenly I am getting a U73 (cable disconnect) error from my DVD player.
The DVD player will play perfectly with any of the cables directly into the TV so it is not the cables, the DVD player or the TV. When connected to the amp, the DVD player will play sound throught the amp until I turn on the TV at which time the DVD player stops and I have apparently got a handshake problem. The same Occurs then I try and connect my Xbox to the TV throught the amp. This however does not happen when I connect another TV to the system, it works perfectly.
The amp otherwise seems to be working perfectly. How can I sort this out?
Thanks
John Torrance
  • 1 more comment
  • john85619 Apr 25, 2010
    No, this is definitely the correct input - I have tried HDMI I and 2 inputs to the tv and tried 2 cables. A tech support guy who was here checking and aerial on another TV was also stumped as he tried his monitor and could get it to work. He said that he thought it was a software issue
    Ok, I have looked again and spent hours with this. The Input to the amp is HDMI 1 input on the amp - no problems. As long ans the TV is off, this works and I get the sound track from the DVD through the speakers. If I turn the TV on , no problems - it works. If I choose any input to the tv (HDMI 2, 3 4 or the av inputs, no problems, I get sound but no picture. If I choose HDMI 1, the input I have used from the amp to the tv, there is no input - the amp says no signal and the dvd player shows a U73 error and the sound stops. There is no adjustment or alteraltion for the HDMI input on the TV.
    So again, the error must be happening in the connection between the amp and the tv and it is the correct input into the correct HDMI.
    Resetting the AMP and TV to factory resets did not fix this
  • 2,335 Answers
I have seen plenty of problems with HDMI interconnects.
May I recommend that you use component cabling for video instead; the picture quality is superior to HDMI, most agree. I also find I have far fewer problems with clients when they accept component over the apparent 'ease' of HDMI's 'one cable solution'. Many people have trouble with their sets giving errors when switching from HD content to non-HD content using HDMI, never component for example.
Additionally, I would add that while I personally run all my av components through my av receiver with HDMI, I also run them all directly to my tv with component cabling. This allows me to cut out the av receiver from the signal path when I want the best picture possible. I cannot recommend it enough.
I hope that helps.
Posted on Apr 25, 2010
  • 4,924 Answers
It seams that the problem is the input of the tv ...try to select the right device in the tv hdmi ...if it works in another tv ..the problem is there ..so go to the menu and reselect the hdmi in for the amp...if you do not know which on e..get them one by one...but the issue is there ...specially if it worked...probably te problem occurred after you connected another kinda device on hdmi ..and it switched the port or the band....
  • Catalin Turcu
    Catalin Turcu Apr 25, 2010
    I wasn't referring at the actual port ..I was suggested to try and see if it has choices in the menu for this one ...if it worked until then ..it must be functional but just deregulated from the TV settings.. cause if it work in another tv its clear that there is no other issue..
  • Catalin Turcu
    ok ...so this must be the correct setting ..the hdmi 1...for to get image and sound..
    now ..let it like that and see on the amplifier..in this conditions what can you modify around the hdmi input...maybe here is the issue ...or youc hanged something when you used it in anotehr device..
CAN THE panasonic dmp bd35 PLAY 3D BLU-RAY DISKS
I understand the DMP BD35 is a normal blue ray disk player and not a 3D. Please see this manual if you want to be doubly sure.
http://service.us.panasonic.com/OPERMANPDF/DMPBD35-MUL.PDF
However something like a DMP BDT360 will play 3D blue ray discs and you can view it on a 3D ready TV.
http://shop.panasonic.com/docs/operating-instruction/2014/bluray-player/DMPBDT460-MUL.pdf
Aug 30, 2014 | Panasonic DMP-BD35 Blu-Ray Player
Why do my dvd show u-73 and won't play when it is hooked to my onky 806 receiver
U73 indicates the unit is not 'handshaking' with the display device via HDMI. Try a different HDMI lead and see if the problem persists. If so, try it with a different display device.
http://www.avforums.com/threads/panasonic-bd35-u73-error-message.1024722/
Oct 17, 2013 | Panasonic DMP-BD605 Blu-Ray Player
Where can i find a manual for my panasonic DMP-BD35 DVD
Hi Paul,
You can download Panasonic DMP-BD35 at www.retrevo.com. Download is free and it is a safe website, I used it personally.
When you are on the link, just click "Download the Document", enter your email add, confirmation number and then click "Download Now" to automatically begin the download.
Hope I helped you.
Have a nice day!
Jdvillanueva
Dec 16, 2011 | Panasonic DMR-EZ48VK DVD Recorder
Panasonic DMP BD35 player and it will not play Blu Ray discs
Have you put in the correct region Blu Ray disc ?
Is it all disks not playing ?
Try cleaning the laser head with a cleaning disk.
Jul 28, 2010 | Panasonic DMP-BD35 Blu-Ray Player
Onkyo TX-SR606 Receiver Logo
938 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
