posted by DIYDoger on Mar 23, 2008
bosch dishwasher model no sgs5342gb/17 will not fill new water valve fitted
Solution #1
posted on Mar 23, 2008
The most common reason why your machine has stopped filling is not the valve, but more likey you have had a leak and the base of the machine is full of water.
If you take the lid off followed by the left side panel ( held on with 2 torx 20 screws ) the lid has two clips at the back and pushes back from the front.
at the bottom of the metering tank towards the front you will see a Red lever going up to a mircoswitch and down to a float. push the lever down to see if the microswitch reacts. if so the base is full of water. empty out and test. try this first, if no luck get back to me.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE 24 in. GSD2000Z Built-in Dishwasher
GE 24 in. GSD2600GBB Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher
GE 15" Laundry Pedestal for Horizontal Axis Washers and Dryers - White-on-White
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Can you Help with these Dishwashers problems?
GE 24 in. GLD6200L Built-in Dishwasher
Middle wash arm not spinning
Our practically new (about a... Answer This...
GE PDW9700 - Heating Element...
I have had TWO diiferent... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
