Question about Samsung LN-S4692D 46 in. LCD HDTV
Lines on screen for 30 minutes
I get horizontal lines on the right half of my screen screen for 30 minutes and then they go away.
  • ctaylor3 Apr 25, 2010
    This is a great service and I really appreciate the instant response. I will follow your directions and see where it goes. Thanks a bunch!
    Chip
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with you'll have to open the back of the unit and check the connections to the main board and power supply unit. Usually this kind of issue is caused by a cable (LVDS) which connects from the LCD controller to the main board. You can try to unplug it and then plug it back if still its not resolved then you have to replace it. It can also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 25, 2010
SAMSUNG - UE40F6670 LED TV - I have thin black horizontal lines appearing in upper half of screen. They get lighter as the TV warms up but don't go away.
IMPORTANT: Horizontal lines on the screen are virtually NEVER caused by a bad T-con board. Horizontal lines indicate a defective LCD panel (screen). Check ribbon connectors coming from screen and the T-con board first but likely the Panel.
Dec 28, 2016 | Samsung Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Oct 11, 2012 | Westinghouse TX-52F480S 52 in. LCD TV
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Nov 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung LN-S4692D 46 in. LCD HDTV Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
