Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
My 330 homelite is shocking me
After changing the coil it started shocking me. I tore it back down and checked the ground wires. I changed the one from the coil to the ground switch and inspected the other one. I'm at a loss. Could it have anything to do with the new coil?
  • 32 Answers
Your new coil may have a crack or some kind of a electrical leak, replace it and go from there
Posted on Apr 25, 2010
Testimonial: "This makes more sense than anything i've heard so far. I will take your advice and let you know what i find."
I replace the valve cover gaskets on my 2005 Sorento 3.5 cranks over but will not start trials 2 start up but all it does is turn over
ok if the car was running before you change the gasket check all your ground wires you may leave something off, or not have some wire plug in good, if you have a test light check the engine to see if you have a good ground by clipping the test light on the positive battery post and touch the engine and all ground wires the test light should light up when it make contact then check to see if you have power to the coils,i would try and check here more to find out if you got sort out
Feb 25, 2015 | Cars & Trucks
My Lawn mower is not starting even after changing and replacing a new spark plug?
First use a known good plug; new doesn't mean good all the time.
You need to check for spark by seeing if the plug or plug wire will arc to ground. When doing make sure insulate to yourself from it as there a 10-15 kv charge on that wire / plug if the coil is working and you will receive a nasty shock.
If no arc then check the ignition coil by removing the kill (stop) wire from the coil and try for again as above. If still no arc then the ignition coil is bad. If you now receive an arc after removing the kill (stop) wire then have either a bad kill (stop) switch or a short in the wiring.
If you replace the ignition coil the air is .010 -.012 normally on most small engines.
Dec 17, 2014 | Garden
2000 blazer wont start
If you don'nt have spark check for power from coil.If theirs no spark coming out of the coil then replace coil.Just pull the coil wire off the distributor side and ground it against metal and have someone else crank it over while you watch for spark.Be careful don't hold wire by hand you will get shocked.
Jan 03, 2012 | 2000 Chevrolet Blazer
No spark on homelite 330 chainsaw. wire on on\off switch broke. thought to be ground wire. attached to block, still no spark switch in either direction.
The switch grounds the coil and kills the spark. Make sure you dont have a rub through on the wire coming from the coil. Better yet disconnect the coil wire. If this works you will have spark but wont be able to shut it down. Verify good spark, then repair the wire.
Hope this helps, Matt
Dec 12, 2010 | Homelite Garden
Weed eater won't start. changed spark plug,
possibly on/off switch-has it gotten wet? Also check where wiring from on/off switch meets the wiring from the weedeater body.Check those connectors/crimps make sure theyre plugged in /right fit and not wet.Make sure youre ground wire is grounded/attatched/screwed to the machine.Ive had a weedeater get wet twice at the on/off switch and had to bring it in the A.C. overnight to really dry out.It worked.Hope this helps.If none of this does then its maybe the coil(semi-internal-no fun) or the fat wire carrying the spark from the plug to the body(semi-internal-no fun).Good luck!
Jun 28, 2010 | Garden
Homelite 330 shocks me when running
Check your wires, sounds like a grounding issue.
Apr 25, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Car won't start
Did you put a multimeter on the coil and check for voltage coming out of the coil? To do this put the ground lead of the meter on the battery ground, then turn the ignition on and touch the positive lead of the meter to the coil. It should read around 12 volts.
Mar 22, 2009 | 1986 Pontiac Sunbird 2 Door
Homelite 330 has no spark
Hi
First check if the plug wires is conected with the terminal from the rubber boot,pull the terminal out of the boot,crimp it with pliers and slide it back into the boot(has to fit snugly on the plug.Let me know
please.
regards savumihai71
Dec 10, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
79 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
