Matsui PL618 LED failure
My Matsui PL618 will not play DVD's. I have cleaned the lens with a cd/dvd cleaner all it did play the audio. I notice that the LED will not illuminate and hence believe the LED or drice Cct is faulty. Does anyone know where I can repair this item in the UK?
I followed the example of one other user, but with an added step. These were: -
1) Turn the power off
2) Manually move the LED Laser to the outer edge of the unit, apply the power and depress the catch. the motoer moved the carriage forwrad but no LED illluminated.
3) I removed the case and checked the connectors, removing the ribbon cable at the carriage end and reseating it bakc in the connector. You need to be careful as alignment is difficult to get right.
4) Power up and check the LED laser.
In my case this worked fine.
Hope this helps
DaveFish
Posted on Mar 24, 2008
SOURCE:
Game dvd stops in middle of playing
Check to see if the dvd is damaged or dirty, try cleaning it.
You can also try using a lens cleaner in the dvd player.
look for something like this
http://www.amazon.com/Memorex-CD-DVD-Player-Laser-Lens-Cleaner/dp/B00008EM7U
also if you could tell us more about the dvd and your dvd player brand and model, I can see its a GoVideo.
Aug 05, 2008 | GoVideo Televison & Video
Tip
Matsui DVD-122 VCD Fix
Matsui DVD-122 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-122 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-122 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Matsui DVD-122 DVD Player can now play VCD's.
I hope that helps.
___________________________________________
Matsui DVD-122 Region Free Fix
on Apr 25, 2010 | Televison & Video
2000. Why doesn't it play a CD and indicates ER6?
Did you try to clean the lens of your optical reader? A typical product is selle dy Amazon and most retail stores
Memorex CD and DVD Lens Cleaning Kit
Tutorial to use a cleaner is shown in youtube
How to Clean CD DVD Laser Lens in Computer
How to clean DVD or CD player or recorder lens Sony RCD W500C
how to clean car audio player
and much more, just do a google search for
Youtube Clean Car DVD Lens
Jul 25, 2015 | Subaru Outback Cars & Trucks
My CH - DVD 300 sticks a lot when playing. Otherwise it is fine. Do you think this is just the disk that needs cleaning or should we buy a DVD cleaner disk?
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Aug 11, 2011 | Cyberhome CH-DVD 300 DVD Player
My Sony DVD player will accept the DVD but fail to load and play the DVD?
Unfortunately , Some DVD players ,especially brand ones cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 25, 2011 | Sony RDR-VX500 DVD Recorder/VCR
Boss Audio System Model #BV8966B - will not play DVD or CD's anymore & keeps saying "No Disc"
Some DVD players cant read some DVD s and
then it shows either "loading" or " no disc"..
Some DVD players are fine at the beginning but after some time later,it begins to have some problems as you have..This is mainly due to LASER eye problems..
Just in case,quick remedy ,
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
Jul 11, 2011 | BOSS AUDIO SYSTEMS BV8966B Car Video...
I hav lg dvd writer it plays cd but dvd what to do
That is because of a dirty or defective lens. When you have a lens problem the unit may still play CD but not DVDs.
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
Feb 15, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Playstation 2 Disk read error.
try cleaning the disk with cleaner if you dont have cleaner use water
Jan 21, 2009 | Sony PlayStation 2 (PS2) Console
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Ekse
