Question about HP Computers & Internet
My computer was pre-installed with Windows 7 OS. I want to change it to Windows xp what shoudl i do?
    Problem Solver:
  • 6 Answers
You need to confirm that your computer is backward compatible with the older XP OS. You should Google your computer manufacturer and use their 'contact' facility to confirm that this will work.
If you revert to XP you might find that you cannot use programs specifically designed for, or provided with, Win 7.
I would recommend that you stick with Win 7 and use Windows updates for any fixes or patches.
It is a pain to switch from an OS you're used to to a new OS but once you've sorted all the bugs etc with Win update you'll find it's worth the effort. I started with Win 3.0 - in the OS stoneage days!
Posted on Apr 25, 2010
I can't get mynew computer to accept windows xp
Ok so im a little confused.. You have windows 8, windows 7 and xp on your computer??
Did you install the xp os correctly?
Nov 30, 2013 | Belkin Components Belkin Easy Transfer...
Tip
Dual Boot Xp & windows 7
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition)
Now install xp first in one partition. If you have pre installed then avoid this step.
Now install Win 7 in another partition.
After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7.
You have to format win 7 before installing Xp.
Commiting any of trick or Tweak you need to backup your data in another HD partition
on Mar 10, 2010 | Computers & Internet
Driver for traveller is 12 digital camera.My computer has now Windows 7 OS, but i cannot find a driver vor my digital camera "Traveller IS 12". My former computer was with Windows XP and it was workin
Using Windows XP Mode, you can run programs that were designed for Windows XP on computers running Windows 7 Professional, Enterprise, or Ultimate... Go here (microsoft web site) to find out how to ... It's not super easy, but neither is very hard to do.
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Nov 22, 2013 | Cameras
Can I downgrade Acer AOD255-2509 from Win7 Starter to WinXP?
you can install win xp ... as a second os ,,, or you can uninstall win7 and install a fresh copy of xp ,,, but you may need a copy of xp with ahci drivers included or else you'll get ( can't find any hard disc ) message ... win7 don't support upgrading or downgrading from another windows version (vista,ex...etc ) or to another version ...
Mar 08, 2012 | Computers & Internet
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
I have a ce-100 futura sewing machine that will not work with windows 7 what do i need to do to fix this problem
The Futura software and the machine drivers exist for Windows 98, NT, 2000, ME, or XP. If you have Win7 32-bit, you may be able to run in the compatibility mode. Load the CD into the optical drive, then right click on the .exe file on the CD. Then choose Properties. Select the Compatibility tab and check Run this program in the compatibility mode. Click Apply and OK. Then right click again and choose Run as Administrator. This isn't guaranteed to work since the changes in the OS are significant.
To check if you have Win7 32-bit or the 64-bit version, click Start > Control Panel > System and Security > System. The title will say Windows 7 (Version) for a 32-bit OS. It will read Windows 7 (Version) x64 for the 64-bit version of the OS.
If you have the 64-bit OS or the compatibility mode doesn't work, you need a computer running an older version of Windows. This can be a second computer, a dual-boot computer (where you select your OS at startup) or a virtual computer (that runs inside the real computer). If you have Win7 Pro or Ultimate or upgrade to one of those versions, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
(The last person I dealt with with the issue of an embroidery machine not talking to Windows 7 kept their old Windows XP computer just to work with the sewing machine. Fortunately the old computer was still working enough to use for the purpose.)
Jun 28, 2011 | Singer CE-100 Futura Computerized Sewing...
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Jun 25, 2011 | Broderbund American Greeting CreataCard...
My windows OS is not genuine. How can I change my operating system without using CD? or free download
Unfortunately if you don't have your CD key, there's no way you can make your Windows XP genuine, without purchasing a new one or installing a valid copy of windows. However, there are operating systems out there that are free to use. Linux is a great operation system capable of nearly anything. Depending on what you are using your PC for now it may be an easy and great switch. Pinguy OS is a variety of Linux designed to be easy to use for any user. All you need to do is download it and install it to a disk. Pop in the disk and restart your computer to install. If you prefer windows, now is a great time to get a genuine copy of Windows XP for a cheaper price now that Windows 7 is available, or you might even consider making the change to Windows 7. It's really a great OS! Hope this was helpful. Here is a link to Pinguy OS: www.pinguyos.com
Jan 05, 2011 | Microsoft Windows XP Professional
When I try to revert back to Windows XP From Windows 7 it asks me for a password that i don't know.
I think your problem is this, you try to install Windows XP with a pre-installed Windows 7---windows doesn't accept downgrading of O.S., so the best solution on this would be to erase Windows 7 or format the hard drive and install a fresh Windows XP.
Jun 04, 2010 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
