Question about Uniden BC340CRS Base Scanner
I programed my scanner but only one channel comes in. Why are not the others coming in?
  • 161 Answers
Check the squelch, it is there to keep the weak channels from stopping the scan.
Posted on Apr 25, 2010
Clear Channels
On SOME of these radios, you can hold down the #2 key and the #9 key at the same time that you turn the radio on, and it resets all data in the scanner. Let me know if that works.
Feb 20, 2013 | Uniden BC248CLT Base Scanner
How do i program a apco 25 freq into the scanner
Just program a p-25 apco into a regular channel of your scanner... in your conventional scan mode...Just go to a certin channel of your scanner and program it in and it will automatically come in the APCO -P25...I have one of these scanners....ITs a wicked scanner...a good one...
May 02, 2011 | Uniden BC796D Base Scanner
GRE prs 295 channels locked out
This message usually means that the scanner has been cleared of all programming. Press the MANUAL key repeatedly to review channels. If 000.0000 shows, it means that you need to program the unit.
Need the manual for your scanner? You can download/print it here:
http://www.greamerica.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=1010
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 08, 2010 | Radio Shack Pro-97 Handheld Scanner
How do i program my sc150b
To program your scanner:
- Turn the scanner ON
- Press SCAN
- Press DCBNK
- Press HOLD
- Enter the number of the channel you wish to program
- Press HOLD
- Enter the frequency, including the decimal point
- Press E
To program another channel, repeat the above - starting with channel number
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/SC150Bom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Apr 10, 2010 | Uniden BC60XLT-1 Handheld Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
BC370CRS Scanner will not work
Are you certain that the frequencies you programmed are active in your area? Does the scanner work on the weather band, service search, or AM/FM?
Dec 31, 2009 | Uniden BC370CRS Base Scanner
The frequencies on my scanner are not coming in
while the weather channel is coming in hi LO (lockout) so that if its programmed into a regular scanning memory it will skip. If that dont work look for a lock button or keyboard lock and press that then scan.
Mar 07, 2009 | Radio Shack Pro-95 Handheld Scanner
Programming bc147xlt uniden scanner
to program the uniden bc147xlt use the manual button to select channel you want to program. punch in the desired 6 digit frequency then press E, press review to check that frequency was input correctly then use the manual button to go to next channel for programming.MAKE SURE WHEN ENTERING FREQUENCY YOU INPUT THE (.) AFTER THE FIRST 3 DIGITS FOR EXAMPLE GO TO CHANNEL 1 PRESS 149.220 E AND YOU should have no problem programming . hope this is helpful
Dec 11, 2007 | Office Equipment & Supplies
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
Uniden BC340CRS Base Scanner Logo
82 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
