Question about Naxa Electronics NX-542 13 in. Portable TV
When scanning for channels it will scan the old ones but not didgital. Have I turned something off on the remote by accident?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Go into the menue and make sure you are digital tunner and scan them threw the auto program mode
Posted on May 10, 2010
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
I have toshiba model CT-90325 . When i type in a channel number such as 25. It goes to a different channel such as maybe 27 or 42. Sometimes when i use the up arrow channel key, it will go in order for a...
Hello... It sounds like you need to run a channel scan. If you have the owners manual, it should walk you through how to do that. I searched online for one, but couldn't find one. I seem to remember something like "Terrestrial" for Auto-programming channels. I hope this helps!
Nov 17, 2017 | Toshiba Televison & Video
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
Nov 10, 2013 | LG 32LD350 32 in. LCD TV
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
I do not know how to do a channel scan, can you help me please? I seriously thought that I could find anything online but I have not been able to find how to channel scan this tv.
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
(low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
Apr 29, 2011 | Televison & Video
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
Radio Shack (Realistic) PRO-2020 Scanner stuck in Scan Mode
Sounds like old age - the 2020 is nearly 30 years old! Have you tried just using the LOCKOUT feature on all channels except the you want? How about just programming the same frequency into all 20 channels?
Jul 25, 2009 | Aiwa AV-S17 Receiver
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
TV scans for channels and wont stop.
I've seen a similar problem like this caused by a stuck button either on the set or the remote control. IF one button has no effect then that's the one that's bad. This might also be your problem. If not then something has failed in the system control circuit. Stargazer
Aug 18, 2007 | RCA TruFlat 27F520T 27" TV
Naxa Electronics NX-542 13 in. Portable TV Logo
138 people viewed this question
Top Naxa Electronics Televison & Video Experts
Paul Gustar
Dung Maurice
Dung Maurice
Level 1 Expert
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
