Question about Hifonics XX-Zeus Car Audio Amplifier
Does this amp have dual 2GA inputs-Hifonics XX-ZEUS
  • ambyrell1 Apr 25, 2010
    I'm talking about the actual power wires, i have found specs for this amp that say it does and some say it doesn't. Also I have seen mono amps with dual power inputs.
  • 632 Answers
Mono amps have single power in so if it is stereo then it should have two.
Posted on Apr 25, 2010
Bridging hifonics vii
find the minimum impedance supported by your amp so you dont burn it up.
look here.
http://www.the12volt.com/caraudio/boxcalcs.asp
Oct 14, 2013 | Car Audio & Video
Protect light amp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
would definitely look at getting it repaired. These new amplifiers can't hold water to an old school Zed audio hifonics Zeus.
Jul 31, 2013 | Hifonics XX-Zeus Car Audio Amplifier
I have a xx zeus 1600 rms amp when i plug in the bais control knob the musuc cut of and protect light comes on what can be the cause knob dont even light up
did bias plug come with amp or is this aftermarket?
bias knobs are manufacturer specific. do not assume 1 bias control will work with different amps.
(even though the RJ11 jack is similar, they are wired differently)
your lucky your amps internal circuitry is detecting the short your introducing.
May 08, 2011 | Hifonics Brutus BX 2005D Car Audio...
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Hifonics zeus z400 red diagnostic light blinks on a bench test ? whats that mean any one know.
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and or a channel or power supply and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 12, 2010 | Hifonics Zeus Z400 Car Audio Amplifier
Protection fail
DISCONNECT THE SPEAKERS AND ALSO DISCONNECT THE RCA INPUTS. POWER THE AMPLIFIER UP AND SEE IF IT GOES INTO PROTECTION. IF IT DOES, MAKE SURE ALL POWER CONNECTIONS ARE GOOD AND IF SO, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. ALSO NOTE THAT AT NO TIME SHOULD YOU PROVIDE AN INPUT SIGNAL WITHOUT CONNECTING THE SPEAKERS, SO MAKE SURE YOU DO DISCONNECT BOTH THE SPEAKERS AND RCA INPUTS AS DESCRIBED ABOVE. HOPE THIS HELPS TO POINT YOU IN THE RIGHT DIRECTION.....V
Dec 28, 2009 | Hifonics XX-Zeus Car Audio Amplifier
Where do i plug the rca cables at? there are two different places
Plug into the ones that say input, the other ones are to plug another amp into, so for just the single amp setup plug into the input.
Sep 15, 2009 | Hifonics Zeus ZXi ZXi 1006 Car Audio...
I HAVE A ZEUS ZS12 350 WATTS AND IT HAS THREE HOOK UPS ON THE BACK HOW DO i HOOK THEM UP
This is a dual coil sub . Go to :
www.colomar.com/Shavano/dvc_spkr_wiring.html
There are several ways to hook up this type of sub. The web site will explain.
Jun 30, 2009 | Hifonics ZS12 12in Zeus Round Version Car...
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
XX- ZEUS MONO D- CLASS / 1600 WATTS RMS
It's likely that the amplifier has shorted output transistors. If that's the case, they will have to be replaced. If you have zero experience with electronic repair, you should pay someone to repair it instead of trying to repair it yourself.
Let me know if you have any other questions.
Jul 28, 2008 | Hifonics BX1500D Car Audio Amplifier
Hifonics XX-Zeus Car Audio Amplifier Logo
76 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
