Question about HP PSC 1610v All-in-One Printer
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and print. Turned it off, turned it back on. . . constant. Please help
    Genius:
  • HP Master
  • 1,354 Answers
FLOWO THE STEPS
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Apr 25, 2010
  • dear sir if your not seticefied with my solution please rejected me or accept
  • dear sir
    are seticefid with ansser then please accept and reject it becoz it too long
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
    Issue
    The power light and resume light is blinking.
    Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
    Load paper in the paper tray and press the resume button (c01219285.bmp ).
    Try to print the job. If the issue continues, proceed to the next step.
    Solution two: Clear the paper jam
    Step one: Clear the jam from the back and top of the product
    1. Remove any paper loaded in the output tray.
    2. Turn off the product.
    3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
    4. Locate any jammed paper inside the product and pull it out towards you.
    5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
    6. If the jam is there, carefully remove any jammed paper and close the cover.
    7. Replace the rear access panel or duplex unit.
    8. Open the top cover.
    9. Check for and remove any jammed paper by gently pulling it out.
    10. Make sure that there are no scraps of paper stuck between the rollers.
    11. Close the top cover, turn on the product, and resend the print job.
    Try to print the job again. If the issue continues, proceed to the next step.
    Step three: Service the printer
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Cause
    The product might be out of paper or there might be a paper jam.
    Feb 28, 2011 | Office Equipment & Supplies
    Paper jam
    Dear sir,
    i am giving u setp to solved your problem,
    Step one: Remove any loose paper.
    Step two: Clear the jam from the back of the All-in-One
    Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
    Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Error message carriage jam and/or paper jam
    Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
    utube.png You-Tube video "wPjahOY5CDo" placeholder
    Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
    Middle light blinking message says paper
    Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
    Sep 22, 2009 | HP DeskJet 550c InkJet Printer
    The screen keeps saying that there's a paper jam in my printer but i kept checking and checking, there's nothing in there. But the printer won't take in the new paper cuz of this invisible paper jam.
    give this a try
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 12, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    Paper jam
    Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
    Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
    Canon ip1300. Three orange flashes, one green.
    Hi emdos,
    Did you mean blinking three times in Orange?. Well, the problem is paper jam error occurs in your printer. First, check if any broken paper inside printer. If it so, remove broken paper. If problem still persist, it seems that drive assy broken or paper feed sensor fault. Find more useful article about this below.
    Soruce:
    Canon Inkjet Printer Forum
    Nov 26, 2008 | Office Equipment & Supplies
    HP Deskjet 3940 (Paper Jam)
    I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
    None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
    I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
    Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
    HP PSC 1610v All-in-One Printer Logo
    116 people viewed this question
    Seeker5211
    Seeker5211
