Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Apr 25, 2010
Which compartment do you put the laundry detergent?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
117
Points
11
First cup on the left when you open the drawer, it says main wash
There are 3 compartments . . .
It says the 1st compartment going left to right laundry detergant and stain remover, the middle is for the soaking agent, and the last one is for fabric softner. I hope that helps!
You can download the manual online and I found the info on page 12 of the manual.
I don't have a manual -- where goes the soap?
Did you try and look up the manual on line? It is available on page 12 it tells you were to load it. It is a pull out in the front of the machine with three compartments.
4helpful
Where to put liquid laundry detergent
Hello. The laundry detergent goes right into the basket where you put the dirty clothes. Regards, Joe
PS please rate my answer. Thank you.
2answers
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
9helpful
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
75helpful
4answers
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Excess water remains in detergent/softener compartments
the best thing that you can do is to pull the dispenser out and clean it. the softener works on a siphoning action and if it is a little clogged then it will not work properly
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
