Won't spin out water
I have a Kenmore top loading washer model 110-24642300. Most of the time it will not spin. You have to put your hand inside and turn it to help it start spinning. You can also push the knob turning it off and on. Still it will not spin all of the water from the clothes.
  • Anonymous Oct 11, 2008
    My Kenmore 110 Washer is not spinning at all it isn't the contacts, but I think it either came off a belt or something that is keeping it spinning, I hear the motor trying to run.
  • duoglide Nov 24, 2008
    sometimes it will not go into spin cycle have to open and close lid to make it start or sometimes give it a spin by hand and get it started
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds liek you have a bad clutch assy, not engaging fully, tip the machine back and give a look around teh inner perimeter of the cabinet, do you see brownish oily streaks dripping down, perhaps a pool of oil under hte unit??? if so you need a new transmission(5 year warr) and clutch assy
Posted on Mar 23, 2008
SOURCE:
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
The water in my washing machine does not drain once it goes to the spin cycle. How do i get the water out and what do you think the problem is?
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that it does spin, the problem points to the drain pump and/or clogged hoses.
See the following on how to remove the cabinet and pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Remove the hoses carefully and drain the water into a bucket or tub.
Check the hoses and look inside the pump (try to turn it by hand) to look for obstructions.
If it won't spin or drain, the first thing to check is the Lid Switch.
See the following on how to bypass the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
283 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
