Question about GE Tritonr XL GSD6260JCC Dishwasher
I have a GE Triton dishwasher. The top 2 arms won't spin/spray. I replaced the solonid/pump but didn't help
  • GE Master
  • 12,061 Answers
Www.ajmadison.com/.../PDF_GE_GSD6200J_01usermanual.pdf - United States
http://frigidaireservicetips.com/pdfs/486_5.pdf
User manual, at top, below is a service and repair, ageneric one. use this to troubleshoot & repair.
The best way to get access to it is to pull your dishwasher out, which means you will need to remove the water line, electrical, and drain hose to it first.
Here's the parts diagram of the drain pump, its #325 here:
Undo the clamp #330 and the drain hose#463 then you can remove the drain pump assembly and check for a clog in it, if no clog then I'd order a new drain pump.
Here's the drain pump for your model: Manufacturer's Number: WD26X10016
Posted on Apr 25, 2010
I have a Bosch dishwasher SGV43A03 and the bottom spray arm doesnt spin. It is free to move by hand, is clean inside and has clean nozzles. The water pump is operating the top jet and top spray arm...
Hello this means the circulation pump would need to be replaced. You can purchase the part from the link below. Also there are several articles that explain how to work on Bosch dishwashers.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
My GE Triton XL dishwasher (6-7 years old) doesn't seem to be spraying water. Is this a fixable issue or is it time to replace it?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Dishwashers
I bought a used GE Triton XL d/w with no manual. It worked great but now it is not cleaning anything, when the cycle is over the soap cup is open but half of the soap is still inside of the cup. I opened...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jan 22, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Spray Arm Doesn't Move on my GSD5630d01ww!
When you say the dishwasher is running do you mean that the pump is operating?  If the pump is not pumping water the arm will not spin.  Is there a bottom arm and is it spinning?  If it spins then the pump is working. The upper arm will not spin if it is blocked by hitting a large dish or utensil.  There should be some sort of tube or tower (some are collapsible) in the center of the lower rack that shoots water into the bottom of the spin arm above.   Is it missing, blocked or clogged?
May 30, 2009 | Dishwashers
GE Triton XL Dishwasher not cleaning glasses
Check to see if the spinner holes are clogged with food..or debris...this is what makes the sprayer arms move....water pressure...which is pumped up through the sprayer arms .......I s the pump working...if so....then you may also have some blockage at the base of the pump where the screen is that keeps impurities out of the pump....check to see that food or debris is not obstructing this.
I hope this help....have a good day and good luck...please rate my effort...the Fang
Dec 14, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Middle arm stopped spinning
you may be exactly right. I always start with something simple. spin the spray arm to make sure it goes all the way around with out touching anything. next is the hard partyou would have to take the motor apart and any filters you see and clean out all the debris.
Nov 27, 2008 | Dishwashers
GE Triton arms don't spin
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Sep 06, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water dispenser not spinning
Are both of the problems listed here on GE > 24 in. GSD500X Built-in Dishwashers?
The original problem could be a cracked spray arm (rather simple to fix).
It could be a sever blockage of the pump/motor or impeller that normally pushes the water up to the spray arms. Opening the bottom pump filter and removing all debris in the filter and underneath it is the next step.
If these solutions do not fix it, then the wash pump/motor have begun to fail and are not creating the water pressure needed to properly spin the spray arms.
Good Luck!
Oct 06, 2007 | GE 24 in. GSD500X Built-in Dishwasher
GE TRITON LX Dishwasher
First check your Drain Cup filter it is just under the lower spray arm you may have something blocking the drain... if its clear check the drain pump... does it run a drain out? can you here it make noise? let me know if this helps ?
Aug 14, 2007 | GE ZBD5900D Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
49 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
