Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave sedems to be working but not heating
Microwave is not heating
Microwave sedems to be working but food is not heating
  • 9 more comments
  • Sam Turk Mar 26, 2008
    GE Spacemaker XL1800 that also seems to work fine, but does not HEAT at all. Replace the magnettron?
  • Anonymous Apr 04, 2008
    my microwave works and all but when i try to heat water up or food it does not heat up
  • wtyueio Apr 24, 2008
    Our ge microwave seems to be working as well, but it is not heating up.
  • Anonymous Apr 30, 2008
    GE XL1800 microwave functions normally, but does not heat food. The unit is just over 1 year old. Any suggestions?
  • Anonymous Jul 13, 2008
    microwave working but not heating
  • Anonymous Oct 08, 2008
    every thing else works but it does not heat.
  • wmjlang Oct 13, 2008
    Everything on microwve works, except it doesn't cook and turntable doesn't turn. When you put pressure on door, it works.
  • luckyone1 Jan 18, 2009
    ge microwave JKP85W0A3WW everthing appears to be working but its not heating up.
  • acellis01 Jan 19, 2009
    EVERTHING WORKS FIN EXCEPT FOOD IS NOT HEATING UP. WHER IS THE FUSE CONTROL?
  • Anonymous Mar 01, 2009
    microwave turns on but does not heat food
  • grady1989 Mar 02, 2009
    turntable turns, light's on, but not heating
We woke up one morning and our microwave had no power. I checked the breaker and outlet they are working. Any help
Posted on Mar 26, 2008
Possible solution:
Make sure air intake that cools transformer and mag tube is free of dust clog. I looked at a friends, who complained his was not heating as well as it should. I found a lot of lint like material clogging the air intake. After I cleaned it he claims it works as well as it ever did. The top was very hot while running before cleaning too. Now it gets food hot, and the cabinet gets only slightly warm to the touch.
Posted on Mar 30, 2009
Normally if the microwave appears to work but does not heat it will be the magnetron. There could be other parts that go bad but the mag is normally the prob. I would not suggest replacing this on your own as it is dangerous - get a qualified tech.
If the microwave has no power (nothing on display) then more than likely it will be a fuse. The one that I am referring to is normally found on the left top side and will have 2 black wires going to it. The fuse should have continuity - if it doesn't then it is not allowing the circuit to be completed thus the unit seems dead.
Posted on Apr 05, 2008
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Chances are the problem is a loose connection on the magnetron, a bad high voltage diode, or a bad diode.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 20, 2008 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
This is usually a shorted high voltage rectifier diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If not, here are some links you or someone you know can use for test help, but read their safety warnings first:
Aug 08, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,195 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
