I have a Panasonic DMR-EH50 DVD recorder with 100 GB HD that locked up in error mode when I tried to divide a title on it. It's not the 'U99' code I keep reading about, Just says "An error has occurred, please press enter". None of the reset procedures work. It just loops with: boot up - boot down - boot up - an error has occured - boot down. And that repeats itself.
  • mcoldiron Apr 25, 2010
    No, it is no longer under warranty.
    I received a good, timely response to my question.
  • 4,889 Answers
The error you are quoting indicates a communication error with the hard-drive. Every time the device is intialized the DVD recorder performs a self-test to see if all the components are functional. If there is a problem with the drive then it will repeatedly keep testing until the hard drive passes the test. What I think happened is that your drive connector is either loose or there is problem with the drive(these drives crash some times . Note that DVD recorders use the same 2.5" USB powered drives that the laptops use). WHich begs the question "Is the unit under warranty?"
Sai.
Posted on Apr 25, 2010
  • eagle338
    eagle338 Apr 25, 2010
    Then I am afraid you have to get it fixed for a fee. Only panasonic guys can get it into recovery mode and fix it. I wish I could say that you can do it yourself but you can't as the HDD uses an encrypted file system that is different from the regular file systems used in windows or any other OS. You can use search for the nearest service center by zip code in the page below. This will not only ensure that you avoid shipping cost but also that you get it fixed faster.
    http://www2.panasonic.com/consumer-elect...
U99 error code on dmr-es35v panasonic recorder what is this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to many popular devices are given.
Feb 12, 2015 | Panasonic DMR-ES35V Multisystem Code free...
My panasonic vhs/dvd recorder DMR-ES30V. DVD will not open and shows error code U99
Error indication u99
After development of the DVD drive and the frame lying under this the cause is nearby a horizontally placed circuit board one Elko 630 uF lid which ones probably lifted presumably is.
Jan 11, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
While trying to save parts of a TV-programma I recorded on mij Panasonic DMR EH50 DVD-recorder I try to delete the parts that are'nt useful to me. The recorder gives the following message: Can not 'work'...
Highlight the recorded program on Direct Navigator then press the Sub Menu button on the remote, then select "Shorten Title". Press (Enter) at the start point and end point of the section you want to erase, then use the up/down button to select "Next". Then, select "Erase" to delete the unwanted sections. Repeat this process for all unwanted parts, then select "Exit" to return to Direct Navigator.
Nov 01, 2010 | Panasonic DMR-EH50 DVD Recorder
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Looking for the region codes!
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Jun 24, 2009 | Panasonic DMR-EH50 DVD Recorder
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
