Question about RCA DCM315R Modem
Opening Ports How do I get to the page and login to make port settings? I need to get to 3074 so my XBox Live will connect to the internet and my provider, Mediacom, refuse to help me at all since it is an XBox Live issue. The Supervisor hung up on me.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Unfortunately, you will not be able to log into your modem and change any settings.
You will have to log into your Router that is connected to your Modem.
You can do this by the following:
Step 1. Click Start - Run
Step 2. Type CMD and press enter
Step 3. At the Command Prompt type IPCONFIG
Step 4. You will be shown a Gateway IP address
Step 5. Open a web Browser and type in the Gateway IP address and hit enter
Step 6. you should be prompted for a user name and password
Step 7. If you haven't set the username and password try Admin for the username and leave the password blank.
Step 8. Once in, you can click on teh tabs until you find a section for opening ports, find or enter the ports you want open
UDP 3074
TCP 3074
Be sure to Rate/Vote
Posted on Apr 25, 2010
Testimonial: "Thanks very much. This was quick and very clear directions. Very much appreciated."
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
Im trying to connect to live and I connected to the internet but not xbox live
Xbox live requires some ports to be open on your router. Make sure the following ports are forwarded through your internet router to the IP address of the Xbox.
On Xbox's site below they have some instructions for the most common router manufacturers.
From the Xbox website: http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/kb/xbox-kb.aspx?kbid=908874
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 80 (TCP)
Note If you cannot chat with someone using Video Kinect, you might need to open port 1863 (UDP and TCP).
Mar 03, 2011 | Computers & Internet
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
My ports are not open and my internet say you nat type is moderate
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Jul 01, 2010 | Microsoft Xbox 360 Elite Console
I have a BEFSR41 Lynksis router and when i try to connect to xbox live it tells me my NAT type is Moderate and it should be Open. How do i change it to Open?
Xbox LIVE has default ports that needs to be forwarded on the router.
To forward the ports, access the setup page of the router. In your internet browser's address bar type 192.168.1.1.
Leave the username blank and then the password is admin.
Go to the Applications & Gaming tab, click Port Range Forwarding.
In the application field, type XBOX LIVE.
Start End Protocol
53 53 Both
3074 3074 Both
80 80 TCP
88 88 UDP
In the IP address field, type the IP address of the XBOX. Check the enable button. Then save settings.
Sep 26, 2009 | Computers & Internet
Xbox360 elite
contact the router company have them walk u through make sure these ports are open
If you have not already forwarded ports for your xbox through your router then that may be your problem.
The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • May 27, 2009 | Microsoft Xbox 360 Console
    Firewall settings blocking internet from Live. I know which ports need to be open, but i dont know how to open them (I have a U.S Robotics router)
    You must do port forwarding now to resolve the firewall problem. Call xbox on what port you must forward on the router's admin page for the xbox live. If I remember it correctly, xbox live uses port 3074 TCP and UDP, 88 TCP and UDP, 53 TCP and UDP, 80 TCP and UDP
    May 07, 2009 | Microsoft Xbox Live Three Month Premium...
    Gigafast ethernet won't let my Xbox connect to live
    You might open this ports to the Gigafast Ethernet router :
    TCP 80, 3074 and 53
    UDP 88, 3074 and 53
    Note: You'll needing to open these ports to the virtual server or port forwarding under advance settings of the router.
    Mar 06, 2009 | GigaFast Ethernet Gigafast 10/100, 8-Port,...
    Opening nat
    You just need to enable port forwarding for the ports that the xbox live is using, specifically these ports:
    UDP 88
    UDP 3074
    TCP 3074
    You then assign a the static IP you have set on your router, subnet, gateway and dns on your xbox and that should allow your xbox live to work properly with your router.
    Aug 21, 2008 | Computers & Internet
    I am trying to connect to xbox live through my WR850G router
    It sounds to me like you need to open ports 88 through 3074 instead of just opening the two. So this way you open Port 88 to 3074. I can further assist you if you have the router info.
    Dec 19, 2007 | Arris WR850G Router (DHWR850G)
    RCA DCM315R Modem Logo
    345 people viewed this question
    Top RCA Computers & Internet Experts
    Julie Endres
    Jose Velazquez
    Jose Velazquez
    Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
