Question about ASUS P4P800 SE (890552603657) Motherboard
I have p4p800 se motherboard but the Lan driver is not detected, i try to install it but its no work, marcvell 88e8001 ljk
    Novelist:
  • 128 Answers
Go buy a new NIC card, and install that card and the drivers for that new one. Disable the onboard NIC that the drivers wouldnt work . It is not a very expensive problem because you can buy a new card for $5
Good luck..
James
-------please click on some thumbs up 4 me!------
Posted on Apr 25, 2010
  • 22 Answers
Try a firmware upgrade or a service pack upgrade......
Lan driver
The Asus P5PE-VM mainboard uses the Marvell 88E8001 GB LAN controller.
You can download the LAN driver HERE.
Sep 23, 2011 | ASUS P5PE-VM Motherboard
P4p800 se lan driver
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these
will help you
http://download.cnet.com/%7Bvalue=http://www.download.com/wireless-lan-pci-802/3000-2112_4-89941.html
http://download.cnet.com/%7Bvalue=http://www.download.com/vnt-vt6656-usb-802/3000-2112_4-96332.html
http://download.cnet.com/%7Bvalue=http://www.download.com/intel-r-pro-wireless/3000-2112_4-64935.html
Jun 22, 2011 | ASUS P4P800 SE (890552603657) Motherboard
Can u give me asus p4p800 se free audio driver pl...
You can download drivers from below website:
http://www.driverstock.com/ASUS-P4P800-SE-driver-download/6-9-10018-79886/index.html
click and download, then install, It will be work.
Thanks
Apr 13, 2011 | ASUS P4P800SE Motherboard
Hi, i'm trying to install motherboard driver LAN, but only drivers i find is the one with the 'PROUnstl' file? I need to install, not uninstall
Open the link provided by Asus below;
http://support.asus.com/download/download.aspx?modelname=P4P800-VM&SLanguage=en-us
Choose your current operating system from the drop-down menu.
Click the + sign next to LAN to open. Download your LAN driver.
Please check your bios. See page 2-18 in your manual. Make sure your Onboard Lan is set to [Enabled]. Save and exit the bios.
Your system with auto restart. Check windows update service.
Need your manual? http://dlsvr04.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Cheers'
Mike
Aug 09, 2010 | ASUS P4P800-VM Motherboard
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Need help finding vista driver for asus p4p800 motherboard.. this is for the network port...
You have a 3Com 3C940 network interface if it is a p4p800,if it is p4p800 E Deluxe you have a Marvel 88E8001 network interface.Unfortunately, 3com doesn't have a driver for that model for vista and asus doesn't offer support for that motherboard anymore.In still may be possible to work with the xp driver that came with your cd or at their downloat page for that model
http://www.asus.com/product.aspx?P_ID=DYt1Et9MlBChqzLb
and installed manually (control panel>system>device manager) select there the network adapter (probably seen as unknown device) and right click on it > properties and update driver > browse and select the folder where the driver is(must be unzipped) you'll need to select the OEMSETUP.INF or EL2000x.inf and next. A lot of win xp drivers worked for me in that way for win 7 and also any driver that doesn't have an installer.
However if you have an E Deluxe marvell has win vista and 7 drivers at
http://www.marvell.com/support.html
Hope that helps !
Mar 24, 2010 | ASUS P4P800 Motherboard
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
Jan 14, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Lan card driver
Hi macubex,
In what manner did you attempt to install the lan driver?
Did you run the *.exe? Try a more direct method. First go to this Asus link. (Click on the link). http://support.asus.com/download/download.aspx?modelname=P4P800-E%20Deluxe&SLanguage=en-us
Look to the right & choose you're OS. (Win2003).
Click the + sign to the left of LAN. Create a folder on you're desktop. Download & save the file: (Marvell_v628.zip) into that folder. Uncompress the .zip file within the folder.
Next click the start button & slide up to & click on control panel.
Double left click on System icon. System Properties will open. Click on the hardware tab & than click on device manager button.
Scroll down to Network Adapters & click the + sign. There should be a yellow ! point. Right click once on the yellow ! point & slide up to & left click on update driver. Windows hardware wizard will open. Click in the circle, No, not at this time & click next. In the next window click in the circle Install from a list or specific location. Than click next. Remove the green check mark by clicking on it once, next to Search removable media.
Than click on the Browse button. Go to you're desktop & find the folder you downloaded & uncompressed the file Marvell_v628.zip.
All you need to do is click on the correct folder & watch the OK button. (It will high light a bit when you click on the correct folder), than click OK & the lan driver should install. Once the lad driver installs, close all windows & restart the system.
When windows finishes loading, load windows update service & check for LAN updates & install it. (All done).
If this fails to work there could be a problem with the Asus integrated (onboard) LAN controller.
Good Luck!
Please let me know if this has helped.
Mike
May 06, 2008 | ASUS P4P800-E Deluxe Motherboard
Try to have the driver of the motherboard p4p800 se sound driver
hello,
You can find your drivers here: http://support.asus.com/download/download.aspx?SLanguage=en-us
Pls input necessary data about your motherboard.
may this help
melnavz
May 02, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
129 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
