Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
Can't install new Kohler rialto Flush Value
Had a leaking flush valve bowl gasket so I remove the old
flish valve and when to replace it with a new one. I cannot
compress the flush valve gasket to twist the flush valve into
the bowl. I contacted Kohler and they recommended I heat up the gasket in hot water to soften it up and try it. The hot water did
not work. The gasket is about 1/2 inch thick and you need to
compress ir about 1/4 inch. This is a once peace toilet with a
rectangular flush valve and you just can't get any leverage. I had
a plumber come in and after 45 minutes he gave up.
Does anyone have any ideas other than to pull the plug on this
toilet?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
First things first, remove the fill valve, and the flush handle mechanism. This will give you plenty of room to work with the flush valve. Before installing flush valve lubricate tabs with plumbers grease. Now put on a pair of work gloves, pushed down very hard and turn the tabs should slide easy because of the grease. Remember do not alter the gasket, the gasket needs to be compressed to do its job. I know removing the fill valve and the flush handle seems like a pain, but there is no way to get your hands in the proper position to install the flush valve assembly.
Posted on Jan 10, 2013
  • 20 Answers
Take your new gasket to a hardware store and try to find a thinner gasket.
Posted on Apr 29, 2010
  • jspie Oct 11, 2010
    The bowl material is rough so the plastic flush valve teeth will not slide across it under the pre-load of the gasket. I solved this by lubricating the gasket where it touches the bowl, the triangular plastic teeth and underside of the bowl flange with I-D Millennium personal lubricant. I-D Millennium is pure silicon. Once everything is covered (be careful to keep it off your hands or you won't be able to hold the parts) the valve goes in and can be rotated into position. Other silicon lubricants may work but I had this one on hand.
  • JOHN LEONARD Jul 13, 2013
    jspie, Kohler has nothing I can find on its website to deal with this problem. The flush valve gaskets on my 3 Santa Rosa toilets all started disintegrating, and when I removed the first flush valve, after tremendous effort, the tabs broke. So I ordered the flush valve kits, and it is impossible to get them in. They came from Kohler with no instructions, so I finally found your solution, but even that won't work. What a poor design!
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
Leaky Seal
By leaking do you mean onto the bathroom floor, or is water escaping out the flush valve (the part that the Hydroright is seated in) into the toilet bowl. If the former 1) check toilet tank mounting bolts/gaskets for deterioration or looseness. These are usually 5/16"x3" brass bolts with rubber, plastic, and metal washers with a nut. They can be seen protruding through bottom of tank. 2) check flush valve and rubber gasket between tank and bowl. The flush valve is the one that the refill tube goes into and the hydroright seats into.
If you are only leaking water into bowl I would suggest the blue dome gasket ( part of Hydroright kit) is not properly seated properly into flushvalve, and you may have to re-install hydroright (the instructions explain how to remove and re-install) . I broke my existing/old flush valve at the base when trying to install my Hydroright so maybe it was fortuitous that it broke and I had to install a new one. Hope this helps.
Dec 15, 2013 | HydroClean Hydroright Dual Flush Converter...
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Please tell me how to replace the gasket on the flapper assy.
flapper.jpgFlapper or flush valve needs servicing
First try cleaning minderal deposits from around the valve seat. This can keep the flapper valve from sealing properly and allow water to seap into the bowl. First turn of the water and flush the toilet to empty the bowl. You can unhook the flapper valve to get it out of the way. Using emery cloth scrub the inside of the valve seat to remove the mineral deposits. Next coat the valve seat with petroleum jelly to help the flapper valve make a tight seal. Replace the flapper valve, turn on the water and check to see if the water still leaks.
If the flapper valve is old it may be deformed. In this case you will need to replace it. You can unhook the valve and remove the lift chain from the valve. Be sure to purchase a similar size replacement valve.
If the valve seat is damaged you will need to replace the entire flush-valve assembly. You will need to remove the tank to do this. Be certain to turn off the water supply and flush the tank to drain it. You might also want to place newspaper and towels on the floor to soak up any water that may leak out. Using and adjustable wrench loosen the nuts at the supply tube and push the tube aside. Next, use a flat-head screwdriver to hold the bolts inside the tank still while using an adjustable wrench to loosen the nut on the bottom of the tank. You will then be able to lift the tank off of the bowl. Lay the tank on the newspapers or towels.
To replace the flush-valve assembly first remove the old one by unscrewing the locknut on the bottom of the tank. Use a hacksaw to cut the new overflow pipe to 1/2 ince below the tank top. Put plumber's putty on the washer at the base of the flush-valve assembly and push the assembly against the tank opening, removing any excess putty. Use a monkey wrench to tighten the locknut. Replace the gasket over the locknut and replace the tank on the bowl and reassemble them.
Jun 15, 2011 | Kohler - Toilet - Two-piece - Highline -...
Can't see how to remove K-4504 tank flush valve to replace it.
You have cut off water supply and empty tank there are 2 or 3 tank to bowl bolts remove bolts then there is a big nut under tank to bowl gasket undo large nut then install new flush valve,gasket and bolts be sure to install as old one came off.
Jun 04, 2011 | Kohler Plumbing
What could be the cause of leak after installing new gaskets and screws, above back/rear screw? 1) not from screws 2)tank not cracked 3)securely tightened all 3 screws 3a)hand tightened(only)large...
Hello, W/D here.
Most probably, the tank-to-bowl gasket has not seated properly. They are usually neoprene, and tend to bight on the bowl socket rather than to slide into the socket where it can be compressed properly. Remove the tank bolts and look at the gasket. Re-install, using a water based lubricant on the bowl side, with the gasket installed on the tank flange. Wiggle the tank and gasket back and forth a few times, and the gasket will start properly into the cast socket on the bowl. Install the bolts and tighten to finger tight. Wiggle the tank a bit more, and level the top. Tighten the bolts uniformly.
You mention that the flush valve was hand tightened only. If this gasket is not snug (a bit more than hand tight), a leak can occur there as well.
Best regards, --W/D--
Apr 05, 2011 | Kohler - Toilet - Two-piece - Highline -...
HOW DO I CHANGE FLUSH SEAL ON KOHLER ONE PEICE TOILET
The flush seal is the rubber gasket between the tank and the bowl. You do not have one. So I am guessing you mean the wax ring on the floor?? They usually only get replaced when the toilet is changed, unless you spring a leak. Or are you talking about the flapper inside the tank that holds the water till the flush lever is pulled? Get a new flapper, if it is just the flapper you need, otherwise you will have to buy the whole thing, all these parts are available at the hardware store. I think it is held on by a couple screws in there, might just be a press fit, we don't see too many one piece toilets. And the wax ring is about $2, but the toilet has to be unbolted from the floor and water disconnected, clean off the old wax, put on the new ring, smoosh it back down and bolt it back it up. Don't for get the water line. Check to make sure you have no leaks. Hope this helps.
May 23, 2010 | Kohler K-3386-0 Rialto one-piece...
Bowl does not fill after flushing
Check the fill line in the tank and make sure it is connected from fill valve to overflow tube. After you flush the toilet it fill's the bowl and tank.
It should be a line about 1/4 ' in size coming from fill valve to overflow tube.
Dec 28, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
What is the procedure for replacing the flush valve assy on a san raphael toilet. it is a one piece tank and bowl assy and must install from the inside of the tank. it appears to possibly rotate into place...
If you purchase the flush valve from Kohler, it comes without instruction. Rotation is the key to removal. First note the exact orientation of the assembly before attempting removal. Unhook the flapper chain and remove the flapper. The old assembly does indeed rotate in either direction for removal. I used a counterclockwise motion. (it was a tough turn, don't break the bottom of the bowl where the valve seat is located.) Then install the new foam gasket on the assembly. The new assembly is replaced in the reverse manner. I removed the new flapper from the flush valve for ease of install. You must put significant downward pressure on the flapper seat while rotation is accomplished. Orient the assembly as was the old one. Replace the flapper, connect the chain and observe the flapper for proper opperation.
Oct 03, 2009 | Kohler K-3384-2-0 San Raphael elongated...
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
1,379 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
