Question about Viking VGIC485-6G Gas Kitchen Range
My oven will only up to 300 degrees it does not seem to be holding the heat
  • Viking Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
even though it is burning some, it is not holding the gas valve open as long as it needs to be and is short cycling...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 25, 2010
Why won't the fan switch of after the oven is switch off
Not sure what fan your question refers to, but the fan that removes the heat from above the oven is controlled by a thermostat. It normally does not come on until the air temperature above the oven space is about 300 degrees and does not turn off until it is below 300 degrees.
Feb 25, 2015 | Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Heating element in upper oven heats to about 300 degrees and temperature will not increase.
That seems to me like it could be an issue with the sensor. Ohm it out. It should be around 1100 ohms if it is any good. Check for shorts from each wire of the oven sensor to ground. I have a manual and a TIP I wrote about these Thermadors.
Thermador 301/302 wall oven repair manual
Sep 28, 2010 | Thermador SC302T Electric Double Oven
My gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Sep 07, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Viking VGIC485-6G Gas Kitchen Range Logo
122 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
