Question about Sony Cyber-Shot DSC-T1 Digital Camera
For use with compatible battery only????
Everything was working fine until I charged the battery a few days ago and now it gives me the message 'for use with compatible battery only' when I turn on the camera? the battery is the original one that came with the camera??? any help would be appreciated...thanks
  • 7 more comments
  • Disdainful Jun 14, 2008
    Same thing going on with me. I haven't noticed anything that helps except that it seems to work better when the battery's not at full charge.
  • Anonymous Jun 28, 2008
    Exact same issue...brand new camera. Bought a second battery when I bought the camera and I get message with both. I called Sony and they want me to send it to them to get repaired. Not happy at all with Sony or this camera.
  • Anonymous Jul 01, 2008
    the same problem. message appears every time the camera is turned on... has been going on for a week now
  • zash Aug 13, 2008
    Well the only solution that worked for my camera was to buy a new battery...now all has been fine...I have a feeling that it was the charger that screwed up the original battery. I had lost ithe charger and bought a knockoff from ebay for $10, it worked fine for the first few times then my son put in the battery backwards and the rest is history....
  • gemgoddess Oct 10, 2008
    F***ing frustrating!! My battery was FINE until I charged it. :(
  • Anonymous Oct 17, 2008
    ME TOO! bought it from a random cheap site on ebay.. put it in backwards..ugh
  • shuffleover Feb 03, 2009
    Me too. (DSC T77)
    I bought an Energizer battery ($60 instead of the Sony $100),
    charged it - worked fine for about 30 sec. then, "For use with compatible battery only" - I could take one picture though before it shut down.
    I think Sony has put some special characteristic into their brand of battery and programmed the camera only to work with batteries that have this "special" (read: proprietary booby-trap) characteristic.
    - Any ideas (other than sending the camera back) ?
  • Anonymous Apr 01, 2009
    Same problem with my camera. I will never buy a sony again!!!!
  • juliepd76 May 18, 2009
    My battery is the original one...I used it successfully in the morning, charged it, took it to a party and for the exact same message: "For use with compatible battery only."
    I love my camera and want this problem solved!
    New Friend:
Press the power button + the shutter button + the zoom button,
All once for 5 seconds !!
And your camera will work normally
Posted on Aug 14, 2013
Same thing happened to me! Stupid new charger!
Posted on Jul 01, 2011
I got the same problem, i went to sony service care and they told me that you have to change the battery be cause it has been damaged.
and the problem still hanged and no one know the reason, but 70% it happened cause of the charger ... don't ever plug your battery in the charger too much time. my cam is DSC-W35 ... for me .. no sony any more :(
Posted on Nov 16, 2009
I've heard of this issue with more than one Sony (seems like there was a post in the forum not long ago with the same issue...). If you've bought a new battery, the problem would appear to be in the camera's power controller. With that in mind, I'm afraid you'll have to decide if the cost of repair is worth it, rather than simply putting the money toward a new camera.
Farid
Posted on Aug 12, 2008
    New Friend:
Discharge battery by pressing aluminum foil on battery contacts, ( 10 seconds) then recharge battery but not fully? Lets keep helping each other!
Posted on Feb 06, 2014
This issue is bugging me badly.. I turn on the camera and it says that ****.. I've changed charger and battery; but it didn't work out. So here is my solution for you.. NO MORE SONY CAMERAS' :(.. Cuz its ****........
Posted on May 28, 2012
Same problem for me also. i am VERY mad. however they came out with a new version of the battery i use so THAT may work but idk
Posted on Jul 13, 2008
Same problem for me.... not sure how to fix it. tried taking it out, recharging it, but nothing has worked...
Posted on Jul 01, 2008
How do I fix starting problem in Megane 2004 1.6 16v
Sounds as though there is a charging problem with the car. It starts when battery fully charged but when the charge is low it fails to start. I would get a mechanic to connect his meter to the battery and see if it is charging as it should. It is also possible that something is draining the battery when not in use. Check interior lights are going out when parked up, nothing is plugged into cigarette lighter outlets attached to sat nav etc., things like that.
Jul 14, 2015 | 2004 Renault Megane 1.6
My iphone 3gs will not charge or conect to itunes
REplace your data cable.If not working that also.... check you port of iphone.And try different USB port.
Thanks.
Feb 18, 2013 | Apple iPhone 3G
Tips to troubleshoot battery (seeking) Receiving "Battery not charging" message from computer.
Take it to Auto Zone or O`riellys and they will test it for you at no charge.They can check your charging and starting system also.Hope this helps.Good luck.
Nov 13, 2011 | 2003 Chevrolet Silverado 1500
The truck stalled a few days ago. It was jumped and ran fine. Yesterday it stalls again, but won't the battery won't hold a charge. It was towed to the shop and they said everything tested fine once they...
sound like might have a prooblem with the charging system. if the altenator is not charging the battery while driving then when the battery voltage gets too low (prob around 10volts) then the computers will shut down, then when jump started it gets some power back, and when the battery is charged will all work fine for a while.
does your model have the voltage gauge in the dash? should be over 12 volts when engine running, 14volts is a good charge rate. and should stay up above 12 all the time, with lights on air condon etc...
and altenators can be funny, work sometimes, and not atother times,
Mar 24, 2011 | 2002 Mitsubishi Montero Sport
Sony erricson w705, wont charge the battery, it comes up with a message saying it cant charge the battery please put a sony erricson battery in, but it is a sony erricson battery and when the battery was...
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
Oct 08, 2009 | Sony Ericsson Walkman W705 Cell Phone
Battery Not Identified.
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
Charging system
it could still be the alternator it may have warn brushes or bad reg
Mar 17, 2009 | 2008 Ford Fusion
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Sony Cyber-Shot DSC-T1 Digital Camera Logo
4,645 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
