Question about Refrigerators
There is and ice blockage in my Maytag icemaker. I want to remove the icemaker to fix or further evaluate. How? French Door model MFI2266AEB
  • 2 more comments
  • wdosborne49 Apr 25, 2010
    Page 10 of the instructions explains how to remove the ice storage bin, but does not tell how
    to remove the icemaker itself. I want to remove the icemaker unit so as to see what is obstructing
    it and determine a solution.
    the instructions on page 10 tell how to remove the ice bin. I want to remove the icemaker
    unit that is positioned above the bin, so as to remove the blockage or figure a solution.
    I have an ice blockage inside my icemaker. This is a Maytag, French Door unit, with the
    small ice storage compartment in the upper left
    corner of the refrigerator. Due to the confined space of the compartment, it is
    difficult to see the icemaker area. I would
    like to remove the icemaker unit, so as to
    evaluate what the blockage is and how to fix it. Please tell me how to remove the icemaker.
    thanks for your help
    President:
  • 949 Answers
Here is a cut out from the service manual for your model, if you want a copy of the manual I can email it to you, just need your email address
Posted on Apr 25, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Please refer page 10, in the manual. It provides you step by step instruction to remove the icemaker.
Manual
Thnx :)
  • Shabeeb Sheik Mushtaffa
    Fell free to revert if you need more clarifications.
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Icemaker clicking loudly model #MFI1226VEM7
It may be the ice full arm is stuck remove some of the cubes from the hoper.
Nov 16, 2013 | Maytag MFF2558VE Bottom Freezer French...
I have model # Maytag MFD2561KES french door refrigerator. The ice maker works sporadically. I do not see a pattern around when & why it chooses to work. I have rearranged the items in the...
This could be a tricky problem to analyze and fix, since it seems to be an intermittent problem. On the following website is a list of things that can cause the icemaker to not make ice, and it is where you should start, as far as analyzing and troubleshooting the unit.
Of course, you should make sure your condensor coils are clean, and that the evaporator coils are not icing up.
Here is the site: http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
The following site has diagrams and parts lists for your unit:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170926
In diagram #16, the water filter is part #3. Make sure it's not clogged, and if it is replace it with a good one.
Here is a blog on that website that discusses a similar problem, and may be of help:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23123-water-dispenser-not-working-ice-maker-does.html
Hope this helps, and good luck to you.
Oct 29, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice maker does not work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Maytag MFD2560HES Bottom Freezer French...
Emptied the ice bin for a party and now it does not make ice?
Flip the wire bail down on the icemaker. It is the on-off switch control for the ice maker. When ice is manually removed the bail is normally pushed up into the off position during removal.
Jul 05, 2009 | Maytag MFI2568AE Side by Side French Door...
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
