Question about Texas Instruments TI-89 Calculator
I'm trying to find a chi squared test statistic but my ti 83 plus says err:domain .. what do i do!?
  • kakima May 11, 2010
    One (or more) of your arguments is outside the domain of possible arguments. For example, with the chi-square density functions the degrees of freedom must be a positive integer.
    Could you post the specific function and arguments?
  • 20 Answers
If your solution comes out negative, it will say this because x^2 can never be negative. therefore, your answer is out of the domain of the function and will not register because it isnt a real solution
what function are you using?
Posted on Apr 28, 2010
2 Suggested Answers
  • 102366 Answers
SOURCE: i'm trying to find a chi squared test statistic
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 14, 2010
Err domain
You tried to use an argument to a function that was not in the function's domain. For example, the arcsine function takes an argument from negative one to positive one. Trying to take the arcsine of 2 will generate a domain error.
If you need further assistance, please specify the exact function and argument that is generating this error.
Oct 15, 2013 | Texas Instruments TI-83 Plus Calculator
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
I want to do a chi-square test on the TI-85
The chi-square test is used for a lot more than just contingency tables.
I found one program for the TI-86 (which is basically the same machine as the TI-85, only with more memory) which claims to do the chi-square goodness of fit test.
You might also want to browse through this archive.
Nov 29, 2012 | Texas Instruments TI-85 Calculator
Whenever i try the graph on my TI-83 Plus the ERR:INVALID DIM 1:QUIT comes up and ive checked the STAT PLOT and i have Plot 1 set as ON.
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
Sep 09, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: what does ERR: DIM MISMATCH mean?...
Imagine you are doing statistical calculations with two list, say L1 and L2 but one list has 10 elements (values) while the other has only 9. The dimension of the lists are different (mismatched) because one is 10 and the other 9.
Another case is if you are manipulating matrices such as adding a3x3 matrix to 3x2 matrix. Both matrices have the same number of rows but different numbers of columns.
May 18, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Clearing or correcting an error message on the TI-83 Plus
Press [STAT] to open the Statistics editor. From the menu that displays, select PlotsOFF and press [ENTER] twice. The calculator answers "Done".
Open the [Y=] editor to enter the functions to be drawn. Use the Trace ONLY after the graph has been displayed.
To clear any message without necessarily removing the conditions that yield the error press the CLEAR button.
Apr 13, 2010 | Texas Instruments TI-83 Plus Calculator
How to do a t-test on the TI-83 Plus
Easy:
1.) Turn it on ("ON" button)
2.) Hit the "STAT" button
3.) Hit the Right arrow key Twice
4.) Hit the down arrow key once or hit the "2" button
5.) Enter your Data into List one (L1) OR Right Arrow once and "ENTER" to just enter your statistics
To just Enter the Statistics:
Down Arrow once and Enter:
Hypothesis mean
Sample Mean
Standard Deviation
Number of Tests
and Either (not equal to)Ho , <Ho , or >Ho
Then either hit Calculate or Draw
If this is confusing try this website:
http://cfcc.edu/faculty/cmoore/TI83TTest.htm
Apr 16, 2009 | Texas Instruments TI-83 Plus Calculator
I don't have a chi square goodness of fit test, where can i find?
You can find the chi-square test for two-way tables and the chi-square goodness of fit tests in the STAT TEST menu (STAT Left).
You can find the chi-square probability density function in the DISTR menu (2ND [DISTR])
Mar 31, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-89 Calculator Logo
1,416 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
