Depending on what leads you have and what connections your equipment has depends on how you would wire it up for a basic setup you need a set of three male to male rca a leads consisting of a RED WHITE and Yellow plugs at each end. Now on the back of your dvd player there should be three female holes the same colou as your plugs and near those holes it should say input plug the leads colour to colour now the other ends of the lead plug into the section of your amp thats says dvd input with the same style holes as the dvd player. then you need to run another cable the same as you have just used to take the sound and picture to the tv you start of plugging one end into the amp where it says monitor or tv out and then at the other end of the lead will plug into the tv in A/V1 or A/V2 if the A/V1 is being used for a video player or camcorder Yellow is Picture Red is Right Sound Channel And White is Left Sound Channel so only plud the matching colours to each other or you will end up no better off hopefully this helped if you get stuck my email is [email protected]
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at [email protected] and i try to help you. hope that works :)
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Sorry to say, Circuit City is right. These cheap home theatre in a box solutions are very very shady. They put the DVD player, preamp, and reciever all in one little box. Not very handy to adding options or plugs but very very cheap to produce. Ever notice why large home treaters have about 5 big black boxes and a DVD player? This little box is trying to be all of them.
If this was a reciever combo(as zenith wants you to think) then you could do EVERYTHING you were thinking would just make sense. Unfortunately, you trusted Zenith instead of Circuit City(gah i hate saying that). At any rate, if you still have receipt, return it!!!!
I will help you pick a system to suite your needs. I do all the things you want on a system i got for 500 bucks.
