Question about Miele G892SC SS Dishwasher
Miele g 892 sc intake/drain light is lite and unit will not operate
  • 177 Answers
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Posted on Apr 25, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Ask for parts diagram of Miele dishwasher G 892 SC ?
The machine has to be pulled from the hole - and layed on its side - the bottom taken off and the Water intake is connected there
Aug 17, 2014 | Miele Dishwashers
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Miele 863 sc will not run a cycle, it just hums and says check intake drain which we have cleaned and checked all drains and screens
Something may have made it past the drain, is now stuck in the pump or its' intake. Put a tray under it and remove the drain connection to the pump. Unplug the unit first.
Nov 30, 2013 | Miele Dishwashers
Miele G 811 SC Intake/Drain Warning Light Appears... Checked out all the usual possibilities, drainage blockages, intake issues, impeller spins in both direction... all are clear, drains and fills...
I'm having the same problem with my G 811 SC, and have tried the same things, but there aren't any reset buttons (and I called Miele as well as searched the internet for any combination of buttons for resetting it). Anyone have ideas?
Sep 28, 2010 | Miele G 2732 SCI Builtin Dishwasher
I have a G 892 SCU Plus dishwasher and the intake /drain light has gone on
I removed filter basket and under it there was a small chrome rod prodruding horizontally by about 3cm. I pushed this in and restarted the machine. Although the light flashed when I first switched on it went out when I started the prograamme. It is working fine now.
Sep 20, 2010 | Miele 24 in. G892SCU Plus Built-in...
Intake/Drain light is on, some water is at the bottom of machine, not draining
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Miele Touchtronic G894 SC Built-In...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
Apr 15, 2009 | Miele 24 in. G892SCU Plus Built-in...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele G892SC SS Dishwasher Logo
1,057 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
