Just paid a fortune to have a new clutch installed after the spin cycle was putting all the clothes to one side and making it off balance.The clothes were fine and evenly spread before the spin cyclr kicked in. apart from the fact it was still doing it, now the tub wont spin at all. The wire to the clutch does not streatch out like it does when it usually spins, and wont spin at all. The centre adgitator does.There is a loose red and white wire?
    Habit-Forming:
  • 120 Answers
Call the tech back that did the repair,
Posted on Apr 25, 2010
Washer won't shift into spin
with a lot of the machines now they wont go into spin mode if the drum is not balanced properly, like say you had a load of towels in their, well it wont spin as its to unstable to spin without wobbling around so it simply stops at the spin cycle and does nothing, you can try this by turning it on with no clothes in and see if it will go into the spin cycle with no clothes in, if it does then chances are its not weighing the clothes properly and would end up costing a fortune to put right as it sounds like you spent a lot of money on parts all ready, so give i a try with no clothes in and see if it will spin, have you tried turning the drum by hand when its switched off to check for any grinding noises or jerking when you try to turn it by hand, im not sure how the balance sensor works or even where it is as its a new feature in the last few years but people are now starting to have problems with this feature and it stops the machine from spinning leaving the clothes soaking yet, so give it a try empty and see what happens
May 16, 2012 | Whirlpool Washing Machines
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
My machine is spinning, but clothes are still very wet, have to drain and spin at least twice to get them dry enough to put in the dryer
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Feb 08, 2011 | GE Washing Machines
Drum hitting sides of machine in spinning cycle (unbalance)
It sounds like you may have to many clothes in it. Try to remove some or reposition them. Sometimes the clothes get pushed to one side of the drum during the spin cycle and all of the weight to one side is making it off balanced.
Dec 27, 2010 | Hoover Washing Machines
The spin cycle on my washing machine is not working, the clothes are still wet when the cycle is finished
Make sure that the clothes are not too heavy ( jeans and sweats ), and put in the machine evenly. If the machine is off balance, it won't spin fast enough to wring out the clothes.
Oct 14, 2010 | Hotpoint Washing Machines
It goes off balance in the reverse cylce. I just put a new clutch in.
"" it goes off balance in the reverse cylce. I just put a new clutch in. ""
Is that the Spin Cycle? Wash basket is rotating CCW is that correct?
Did you follow this post for the Clutch replacement?
I
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Maytag Atlantis washer that runs fine until the spin cycle. Once it hits the spin cycle, it gets very loud, like it's off balance. When we get the clothes out, they're still soaking.
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Washing Machines
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
