Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore elite top loading washing machine model number 110.2706, 2707, it keeps giving us the message LF, what does this mean?
  • 15,935 Answers
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
What is the LF code on my kenmore elite oasis
The LF code stands for long fill.. I would suspect a water inlet solenoid valve as the most likely suspect. It may be the hot or the cold valve. If the valve does not completely open the time to fill your machine takes too long. You can't replace just the one valve because the part contains all of the water inlet valves. That of course jacks up the cost but what can you do.
Jun 29, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Itshows LF what do i do?
LF code means long fill on the water supply,if it takes too long to fill it will shut down,remove the water fill hoses and check for screens in the hoses and washer water connections and see if they are plugged with sediment
Aug 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
ERROR COAD LF, what does it mean?
Final forth ;-0) (the F could stand for Filter or Fill or LF for Lock Fault ) Hi from retired Englishman in SW France,
Sorry but you have posted at least 4 problems but against different makes and models which makes it difficult to define what your particular 'LF' stands for- different makes, models, often different meanings so here is a practical answer!.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 19, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
and again! Hi from retired Englishman in SW France,
Manual
John C.
Sep 19, 2011 | Kenmore Elite 45986 Front Load Washer
L4 error message on my Kenmore top loading Oasis washing machine?
call 21-341-0097 maytag service with model number aval and i can help you. it is poss you will need a repairman out and we also come to homes in the dfw area and east of dallas. we are a service provider for whirlpool/maytag.
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
LF appears in time remaining window.
LF means long fill (taking to long to fill tub, Check inlet screens inside the valve and sometimes they are inside the hose fitting. Make sure hoses are not kinked & if hoses are over 5 years old REPLACE.
Dec 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE top loader washer; It will start but gives me an LF error.
this is a fault in the water valve control, "LF" means Long fill (fill time exceeeded), so u will need to have the sears guy out to sort this problem out. are the water valves on the wall turned on all the way?
Jul 15, 2009 | Kenmore Washing Machines
The dreaded LF code
HI, there is not a defect notice or recall on this particular unit but, we get a lot of complaints about this specific issue concerning the LF code on a frequent basis. this issue dose concern the inlet valve.
The replacement will work better than the factory installed piece. This is basically a blind defect.(defective factory part).
Jun 19, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
