Question about Coby MP-705 Digital Media Player
MY PLAYER WILL NOT POWER UP WHEN I CHARGE IT ON THE COMPUTER
  • annx40 Apr 25, 2010
    I RECIED IT FOR CHRISTMAS AND IT HAS NEVER WORKED. I TOOK IT BACK TO THE STORE BUT SINCE I COULDNT FIND THE RECIPT THEY WONT TAKE IT BACK. I WAS ABOUT TO JUNK IT WHEN I CAME UPON THIS WEBSITE.
  • 781 Answers
Please confirm:
1. did it ever work? how long have you had item? has it been dropped or damaged besides regular use? - 1 year warranty is usually provided by manufactuer, seller may have sold extended warranty that you may make use of unless item was damaged.
2. do you have an alternative way to charge it? is it only not charging when plugged to the computer? does your item come with a cd for you to install drivers, please run cd, install drivers and software required and test.
3. have you tried a different usb cable? a different usb port? a different computer?? please try to post back with test results
4. check the power switch and try it in each position when attempt to charge.
5. try to reset the switch by using a paper clip and being very careful insert the tip through the a reset hole to press the botton that will reset the device.
6 most devices of this category usually may have firmware updates avaliable from the manufacturer website. if your computer is able to see that your device is connected, proceed to update the firmware. (at this time, though there does not seem to be any firmware updates)
if all have failed, your unit may have failed and if no warranty avaliable it may be have to be replaced.
Posted on Apr 25, 2010
How to charge a cativa AT-MP420 portable Media Player
Ti charge the MP3 player, connect the supplied USB cable to the player and then plug the other end of the USB cable into the USB port of your computer.
OR
Purchase a 5 volt mains USB power adapter and plug the USB cable from your player into the USB port on the power adapter.
Aug 13, 2012 | Toymax Audio Players & Recorders
How do I Charge my JNC?
You can charge the MP3 player by connecting the suppied USB cable to the MP3 player and then connecting it to the USB port on a computer/laptop. Don't forget to power up the computer/laptop.
Apr 05, 2011 | JNC Computers SSF-M3 MP3 Player
Hello I bought an Onix Multimedia player from ALDI. How do I charge it? When I connect it to my pc I can't see it? no drive showing it Any chance in getting an electronic version of the user...
1. Please confirm that the power switch (located on the side of the player) is in the up or ON position. 2. When you connect to your computer, please make sure that the computer is powered on and not in a sleep or standby state, as those low power states will not charge a USB device.If that's not working, charge the player in a wall charger or another computer.
Dec 31, 2010 | Audio Players & Recorders
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
Does not charge
Below are some things to check for when your Sansa player does not charge..
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Also try ports on the back of your computer, these ports have more available power. Some computers have limited power to charge up the device...
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Jun 08, 2010 | SanDisk Sansa Fuse MP3 Player
Can this mp3 player charge on my computer with a mini USB?
Hello :
If your mp3 player is chargeable with the computer , then there's a problem with the power jack . You need to take your mp3 for repairing .
good luck .
please rate !
Mar 31, 2010 | GPX Audio Players & Recorders
The mp3 player won't charge when I plug it into the computer and my wife's won't accept any more playlist
I dont know about the playlist. But if the Sansa LION battery goes too low it shuts down. When you plug it into your computer to charge the player, It usually powers up so the computer can detect the hardware being plugged into the USB port and provide power for charge.
You need to plug in the USB cable from the player to the PC and perform a system reset - Press and hold for 20 seconds the power on button and the play button (>||). this should work you may try it on your wifes player?
Feb 06, 2010 | SanDisk Sansa Clip MP3 Player
How do i charge it
Three way to Charge you Battery...
1. Charge with USB Cable- Use usb cable and directly connect to you mp3 player, And another attach to the computer.
2. Charge with Charger - directly connect to AC power supply and another attach to mp3 player.
3. Directly Boost - Another way to charge, open your mp3 player and charge your mp3 battery directly (+/-) point with Zapper (zap gun) - It will boost your battery immidietly.
Jan 28, 2010 | Audio Players & Recorders
How do i charge my mp3 player/sandisk sansa m240
Connect the USB cable to the MP3 player then power up a computer and plug this MP3 and cable into the computer's USB port.
You can also charge it by purchasing a 5V USB power adapter and plugging the MP3 player and cable into this adapter.
Jan 04, 2010 | SanDisk Sansa m240 MP3 Player
Charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player. Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Dec 19, 2009 | MyMusix PD-6070 MP3 Player
Coby MP-705  Digital Media Player  Logo
48 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
