Question about Syntax LT30HV 30 in. HD-Ready LCD Television
Have power sound,but no picture - Syntax LT30HV 30 in. HD-Ready LCD Television
  • 1 more comment
  • davis4844 Apr 25, 2010
    seem to have a dull glow,then when the ligt hit look as doe i can see some shadow like move ment not sure
    i cant decide i accept what i can see
    what is my soulution i am still not sure what is the problem
  • 4,889 Answers
Sounds like you have the inevitable backlight inverter/t-con board failure. Turn on the set and darken the room
1) See if you notice a dull glow on the screen If you see a glow then the backlight inverter is functional and t-con board, also known as video driver board is dead
2)If there is no glow then take a torch light. Flash it on the screen from a close distance such that the light travels down the screen Try it from different angles and see if you notice a dull picture. If you see the picture then the t-con board is functional but the backlight inverter board is dead.
Please post back with your observations so that we can proceed accordingly.
Sai.
Posted on Apr 25, 2010
  • eagle338
    eagle338 Apr 25, 2010
    If you can see the glow then it is confirmed that the backlight is functional. We have to find the t-con board for your set. Hope its not integrated in the panel which some manufacturers do. Take off the back cover and the metal plates at the center. The see if you can find a board that looks like this one
  • eagle338
    If the t-con is functional then you will see a clean image for the backlight is functional. So I am sure its the t-con board Read my last post for instructions on finding it.
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
At first, no power, no sound, and no picture. I replaced the power source board. I have power and sound but no picture.
verify your connections you may have the video cable connected to a different input than your audio
Apr 14, 2009 | Televison & Video
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Syntax LT30HV 30 in. HD-Ready LCD Television Logo
101 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
