Question about Kitchen Ranges
My dacor oven will not heat up. The oven is 3 years old. There is electricity going to the unit confirmed by the light on in the oven but the unit will not heat up. Any ideas?
    Habit-Forming:
  • 193 Answers
Thermostat
element
fan not working if fitted to oven
element safety fuse
Posted on Apr 25, 2010
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Oven does not heat up there is power to unit. oven is about 10 years old
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 25, 2011 | Dacor ECS127 Epicure Electric Single Oven
Microwave panel is on, timer works, but no turning or heating. unit is 3 years old
Bottom door switch or mount.
See this file, and the DMT2420 manuals here and here.
You can order Dacor parts by part number from the Pros here.
Aug 14, 2011 | Dacor DMT2420SS Microwave Oven
Our Dacor ECS130SBK convection oven no longer heats, after using the broiler and leaving the door open.
The element is probably failed. Using an oven in this manner (turned on with the door open) is not good.
The element is replaceable, and will require some electrical tests to confirm the failure.
Dec 10, 2009 | Dacor ECS130 Epicure Electric Single Oven
Is there a reset switch for Decor Electric oven? Kids turned on self clean and read out stopped working. Unit is at least 10 years old.
You can reset the oven by shutting down the breaker for the unit for an hour or 2, if your oven is over ten years old it might not help, the board could have been fried, good luck
Jul 15, 2009 | Dacor Ovens
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Oven enamel chipping
Never heard of such a problem, you are the first to post it. There is no fix for this.
Apr 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Kitchen Ranges Logo
106 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
