Question about Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier
What sound does the low mid suppose to give? - Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier
  • 417 Answers
When terms like "low-mid" are used, it generally means frequencies between approx. 125Hz to 315Hz.
Posted on Apr 26, 2010
How to connect bass power subwoofer
Totally depends on the sub and if it has a crossover and if so what sort and if it has a pass through either for mid/tops or parallel. If it has a low pass then take mixer main out to sub, if mid top output then mid top to that, if only pass through then either full range to mid top from there or probably need crossover in signal path to split the frequencies.
Jan 30, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
KRK Rokit monitor has no sound from bottom speaker (the larger speaker for lows and mids) the unit powers up fine and i get sound through the tweeter.
What you are describing is a total component failure of something in the crossover board. You cannot really check a crossover without an oscilloscope and a frequency generator. In a lot of cheap speaker systems, there is no crossover board attached to the woofer. In your case it appears that a low pass filter is present on the woofer. http://circuitdiagram.net/loudspeaker-system-crossover-network.html
Sep 27, 2015 | KRK RP5G2 Pair Rokit G2 Powered 2-way...
How do I properly connect my peavey 118 subwoofer to my peavey 215 speakers
When asking questions please give as much detail as possible, t LEAST give the model or part numbers of the items you are asking about and anything else you will be using with them. Without this information it is impossible to answer more than general questions. However I will attempt to give an answer which could point you in the right direction below.
As you don't say which 118 and 215 you have it is impossible to give an absolute answer. Some 118s have an internal low pass crossover with two inputs in parallel, in this case you can take a connection from the amp to the sub and from the sub to the 215. Again some 215s have a high as well as a full range input so you MAY be able to use this to avoid driving full range into the 215. Some 118s have a high pass as well as a low pass in which case just connect the high out to the fullrange in on the 215. You could also possibly split the amp to use one side as a sub driver and the other for the mid/tops if the amp has a crossover.
You may also find that the wiring on the speakons on the tops needs to be different according to how you are going to use them (2+/- instead of 1+/-)
You will also need to know what impedance your amp is happy to go down to as in some combinations depending on which model 118/215s you have you could end up presenting a 2ohm load.
Dec 10, 2013 | Peavey Music
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
I want to know the best setting of microfone system in concert hall for Mridangam., like bass,treble,etc
The drum has usable frequencies and harmonics out to at least 3KHz so plan on 5KHz.
I would use a Shure SM57 and you MIGHT find it necessary to have one at each end since this is a two headed drum. position the mics pointing at the ends or slightly angled but clear of the hands. If you put them off to the side you may not get quite the sound you want. Set the EQ controls to pass all low frequencies and the mid range up to 5 KHz as flat and reduce the highs above 5KHz to avoid some of the brushing noise of the hands.
Note that the room acoustics and your sound system may play a GREAT part in how it sounds.
Jan 21, 2011 | Mid East Mridangam South Indian Tenor
I have 1604-Vlz3, M-audio Delta 1010LT With Cubase 5 . There is a main problem when it's normal with an apm it's no problem no sound problem but when the direct out is working with the sound card the...
You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
Jan 18, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Amp volume drop with flabby bass sound.
1) can happen if the speaker is dying - voice coil defective or magnet needs recharging. happens sometimes with low quality speakers.
2) faulty pre-amp section can reduce overall gain resulting in lower output volume.
3) for old amps dry solders in pre-amp & power amp section can have the same effect.
4) faulty coupling and filter capacitors can severely effect frequency response too.
Mar 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
Jan 23, 2010 | Music
Ok I give up I have searched for months for a direct answer to my problem.. to be honest I have found several people who have had the same thing happen to them but the solutions are for different...
Check the power adapter UNDER LOAD. It has to do more than just light up lights to be exhonerated. If the voltage is too low, the power on reset of the micro inside will NOT release and it will act dead...
In short, you need more than light to run this.
Next step is checking that the adapter is delivering DC and not dipping down during the power cycle. This you need a scope to test.
Also check that the headphone jack switch is working. If it thinks the headphones are in, it disconnects the speakers.
Dec 24, 2009 | Yamaha Music
For 100 watts it doesn't seem that loud to me. Could I maybe add more speakers (2x10s)?
Our human perception of loudness can be way off. You should get a soundmeter and compare. There are some pretty good ones on eBay new for about $140.
Adding speakers may NOT increase the sound much as the power will then be split between the speakers.
Nov 02, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier Logo
51 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
