Question about Refrigerators
Was vacuuming coils/bottom of fridge and my brush hit the fan and now fan is not spinning. Does the fan always spin or only when called for??? HELP HELP
  • 4,070 Answers
The fan spins when the compressor (motor near the fan) is running. If yours doesn't,make sure you didn't bend a fan blade or the fan housing stopping the fan
Posted on Apr 25, 2010
  • Refrigerators Master
  • 43,501 Answers
If the compressor...the black can in the back...is running then the fan should be running...
if it is not running when it should be, check the fan baldes, you may have bent one or more of the blades and now the fan is stuck because it cannot turn...
If so, just bend the fan blades back stright so they do not hit anything...
heatman101
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
The rubber on the fridge & freezer doors are hot
pull out the machine,remove the front bottom kick plate and then go to the back and remove the back bottom panel,check to see if the condenser fan blade is spinning and check the condenser coil to see if it's loaded with lint and dust.the fridge is running to hot,the way it cools down is the condenser fan blows air around to keep the machine cool and heat escapes through the condenser coil,if it's blocked with dust the heat is held in the coil,a shop vac works great for the coil,vac up as much dust as you can and then set the vac up on blow and blow the dust out of the coil,the coil will either be in the back or on the very bottom of the machine,if the fan isn't running try spinning the blade,it might run or something could be stuck in it,i've found from a piece of paper to a mouse stuck in the blade,if it is the blade you can leave the back panel off and stick a house fan back there to cool down the machine until you get a new motor,if the motor does run after you spin it i would still change it out as soon as possible,if it stops again you could damage the compressor and then it's new fridge time.you should clean the coil at least once a year.hope this helps and next time you need help send the brand name and the model number off of the machine that you need help with
Nov 12, 2011 | Refrigerators
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Kenmore side by side refrigerator is cold inside, but bar in the middle separating the frezzer from the fridge is hot to the touch
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. Ihad inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Aug 25, 2009 | Refrigerators
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
Bottom on the vaccum the spin brush will not spin at all
Double check for anything that might be holding it from spinning (shoe lace, string, hair, ribbon, etc)
If the brushes are free to move by hand, you most likely have either a broken belt or a belt that simply came off the motor. What you'll need to do in either case, is open up the vacuum cover. The screws are usually located at the bottom of the vacuum (where the brushes are) and remove all the visible screws you see.
Most of the time (being that I don't know what kind of vac you have, that is enough to remove the top cover off for you to inspect either the motor or the belt which attaches to the motor. I know on my hoover, the belt slips off very easily, so I always need to keep my screwdriver handy to perform this.
Hope this helps.
Apr 19, 2009 | Vacuums
Middle Wall too hot
There is a pipe with hot gas running through the middle wall to keep the gaskets dry but if itgets to hot probably the condenser coil behind the fridge is dirty ,unplugged it snd brush all the dust and dirt off .That willlower the temperature in the middle wall and it will cold better.
Apr 11, 2009 | Refrigerators
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
816 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
