Question about GE Spectra JBP78 Electric Kitchen Range
How do I replace the bottom heating element. I took out two screws which attached it to the back of the stove and I thought it would just come out but it is still attached. How do I get it out?
Another problem you may see with this (I just fixed it) is a short in the yellow wire. Connected to the right side of the lower burner element. Here are my step by step instructions to fix on JBP78W-Y5:
1. Go ahead and pull the stove out, turn it off. Great chance to clean around it.
2. Undo the screws inside holding the burner in place.
3. Remove the two metal covers on the back.
4. You now have easy access to the terminals on the back of the burner element. Those things slide off, but it may take some doing if they are corroded.
5. The yellow wire connects to the control board at the top. We needed to pry this away from the board GENTLY with a flathead screwdriver.
6. Cut off the burnt end, and put a new AMP Female Disconnect on for 16 gauge wiring. You'll need wire regular strippers/crimpers, and I also needed a razor to cut the rubber. Must be a special coating because my stippers wouldn't touch it.
7. Take that burner out and sand off any corrosion off the leads.
8. Put the burner back in place and tighten it up.
9. Put the two leads back on the burner the way they were and the yellow one on the controller.
10. Plug it in and check if the element will heat up.
11. Works? Great. Turn it off, put the covers back on and put it back in place. All done.
Posted on Jun 13, 2010
  • GE Master
  • 43,501 Answers
just lift the loop part and then pull out, away from the two end parts...the element will just slide out...it may take some force to get it to release...you may have to hold onto the plug end and pul it apart one terminal at a time...
heatman101
Posted on Apr 25, 2010
I replaced the bake element but it will not heat
Have you checked the oven fuse, there should be one on the stove. To check the element power, remove the element from the back where its attached to the stove Remove the element from the wires (Skip this step if you are absolutely sure the element is not working). Attach your meter clips to the 2 wires (meter set set to at least 250Vac), place a piece of cardboard under the screws and meter clips to isolate them from touching any metal parts of the oven. Turn the meter on, set the oven thermostat to 350, you should have at least 220Vac, if you do the power is fine. Test element for continuity, and for a possible short.
Mar 01, 2015 | Dacor Epicure ERD36 Dual Fuel (Electric...
Tip
I'm wondering if my Jenn-Air Model JER8885QCS needs a new probe or not. It's a...
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but can be found with the technical documentation that comes with your range. Most manufacturers place a tech sheet somewhere along the back of the range, or inside the console for qualified technicians to use as a troubleshooting aid. Refer to this if an “F” code is displayed on your operator console. The probe may also exhibit other symptoms without generating an error code. You could have undesired heating results (too hot or too cold), or slow preheat times.
The location of the oven probe can vary on different models as well. It will be mounted on the back or side of the oven wall (usually in the upper right or upper left corner). If you suspect you have a bad oven probe, a resistance check can be performed to determine if the probe is good. To accomplish this, unplug the range and remove the back panel. There are still dangerous voltages present even when the oven is not on. There will be two heat insulated wires coming from the oven probe behind the oven. Disconnect the wires and perform a resistance reading across both wires at room temperature. If the probe is good, it should read around 1100-1200 ohms*. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and can lead to erroneous error codes. Some manufacturers recommend cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. This provides a more permanent and reliable connection. The lugs can be purchased at most hardware stores. A new oven probe roughly costs about $35 - $45 and can be found on line at several appliance parts websites. Higher end model prices may be more.
To replace the oven probe, simply remove the mounting screw from inside the oven cavity, disconnect the wires and pull the probe out. Insert the new probe by feeding the wires through the opening in the back of the oven first and out the back through the insulation (a long screwdriver can assist you in making a visible hole through the heat insulation to feed the wires easier). Once you have the wires through the back of the oven, reinsert the mounting screw and connect the wires leads together. Reinstall back panel.
*NOTE: Keep in mind resistance readings will be higher if the probe is hot. Make sure you check the temperature at room temperature.
I hope this information is helpful..
on Mar 31, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Replace heating element in RB790 ge hotpoint. How remove glasstop to reach element
We had the same problem with ours. This is likely caused by one of two things: The element could be bad, or the element controller could be bad. I hope this helps...
1. Get a screwdriver and multimeter.
2. Slide out the stove and unplug it.
3. Open the oven door and look along the front edge up under the cooking deck. You will see several screws. Remove them.
4. Pry up the top cooking deck, the deck is hinged on the back side of the stove.
5. Lift up the front end of deck and get something to prop it up with.
6. The heating elements are are mounted to sheet metal strips, which are attached to the bottom of the cooking deck with screws.
7. Plug the stove back in and set the bad element to high heat.
NOTE: THE EXPOSED WIRING UNDER THE DECK COULD BE ENERGIZED TO 220V, ENOUGH TO KILL IF TOUCHED! USE EXTREME CAUTION. NO CHILDREN, PETS OR CURIOUS ONLOOKERS NEED TO BE AROUND WHILE DOING THIS. ALSO, YOU DO NOT NEED TO BE DOING THIS IF YOU DO NOT KNOW WHAT YOU ARE DOING.
8. Take the multimeter probes and check the voltage going to the element. If the voltage is 220V, then the element is bad. If no voltage or very low voltage, then the controller is bad.
9. Unplug the stove.
10. If the controller is bad, then remove back cover from control panel. Remove controller and replace it.
11. If burner is bad, unplug burner and remove it...you will need to remove sheet metal strip that the burners are mounted on from deck before removing burner from the strip. NOTE: The burners are delicate, be careful.
11.a Mark the metal mounting strip where the burner tabs attach to it with a marker before removing burner because there are several locations on the strip where different burner sizes could be mounted.
12. The replacement burner is expensive. After careful inspection, I found the burner to be bad on ours, and the cause was a broken weld between the burner element foil where it is tack welded to the wire tab at the side of the burner. Looking at the quality of the welds, I would not be surprised if this is a common problem. One could take a piece of steel, say a paper clip or similar, and use a pair of needle nose pliers and fashion a small clip using the needle nose pliers to compress the break in the element foil back together. Otherwise, replace the element. I opted to repair the element and save the money.
13. Reinstall the element and plug the element in. Note, the element can be installed in several locations on the sheet metal mounting strip. Make sure to install back in the original locations that you marked with a marker. Carefully reinstall the mounting strip to the deck. Screw deck back down.
14. Plug stove back in.
15. Cook
May 22, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Dec 02, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Burner on GE flatop not working
15. Cook
Sep 05, 2008 | GE JBP68 CleanDesign Electric Kitchen...
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
325 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
