Question about Kenwood KDC-MP4028 CD Player
Just bought a used Falcon (2000 AU). The radio & tape deck work but the CD player doesn't - it initially ackowledges there's a CD in there but then ejects it. Can this be fixed or will it need replacing? Thanks!
    Problem Solver:
  • 6 Answers
Maybe it have a bad Lens try and clean it with a CD lens cleaner and see if it does not wortk then maybe you can see if the factory warentee in experied
Posted on Apr 25, 2010
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
2000 Buick Century. Put in a replacement radio/cd/casset player. Radio works, clock works, but CD and casset do not. The message comes up E 13. What does this e code mean?
if its a radio shack radio, it means E13 means "Tape Communication Error". It is caused by the
microprocessor reading speed pulses from the tape deck either too fast, most other makes mean about the same thing, normally a stuck tape will cause this code to show up, either that or the drive gear that loads and unloads the tape is broken, cracked, or jammed
Sep 26, 2011 | 2000 Buick Century
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Hi! I got Sansui DA-T550 reciever which is a bundle with amplifier, FM, tape deck and separately connected automatic grammaphone. THe problem is with tape deck. When the whole unit is turned ON, the...
Hi Taff,
I had this problem too. In the end I opened up the box ( a real nightmare) found a "computer ribbon" style wire between the tape bits and the amp bits and disconnected it. I can't use the tape anymore, but it doesn't make any noise either. Like you (in your solution) I hate the way it switches to the radio when a record finishes. I have a CD player connected to the aux play jacks - when the aux button is pushed in, the radio is disconnected and when the CD finishes, you get silence not radio.
Dec 08, 2010 | Audio Players & Recorders
I want to remove my radio cassette cd player from 2000 au falcon can you help please.
go to walmart and get the set of factory removal tools or the hard way and reach up behind the stereo on the sides and feel for the lock
Sep 13, 2010 | Car Audio & Video
Cannot play ipod on 2000 malibu using tape adapter. malibu has cd player and remote tape deck
Instead use a radio adaptor where you would set you radio to a particular channel. The adaptor emits a signal correspondent to that radio signal and allows you to listen to your iPod.
Jul 08, 2009 | 2000 Chevrolet Malibu
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
CD Player for 1998 Mercury Mystique
I just bought the same car recently and my son installed a cd/satellite/radio player into it with no problems. A high-end one that he took out of one of his cars. He's an audio freak that works in a high-performance car accessory shop. The only thing extra he had to install was some kind of wiring adapter to mate it with the existing factory radio harness. It only cost a few bucks. I think about $15.00. And there was no worries about wattage or anything else. Been using the player for about six-weeks now with no problems. If you remind me, I'll ask him about that wiring adapter....
Joe
Sep 04, 2008 | 1998 Mercury Mystique
How to connect eq to audio amp
To EQ all audio sources you'll need to have a receiver/amp with either a tape monitor loop or a pre amp-in/main-out loop. Look for a button on the front labelled 'Tape Mon' or ins and outs on the back labelled pre amp-out/main-in. If you have these you can connect the outs from the amp to the ins on your EQ and then EQ outs go back into the amps ins. If you have a tape deck as well, the EQ's 'tape mon' jacks replace the ones it takes up on the amp, so just plug your tape deck in here.
Just remember that whether you have a tape deck or not, if you hang an EQ off the 'tape mon' loop you'll have to engage the 'tape mon' button/switch for playback with EQ.
If your amp doesn't have these loops you can still use EQ but you may be restriced to one audio component source. So say you wanted to EQ the playback from your CD player, you'd just connect the CD players output into the EQs input, then connect the EQ's output into the amplifiers input (for CD player). Then everything you play through the CD player will be EQ'd.
Jan 01, 2008 | Audio Players & Recorders
Kenwood KDC-MP4028 CD Player Logo
168 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
