Question about Dell 2300MP DLP Projector Multimedia Projector
HP Laptop and Dell 2300mp Projector says searching for signal. What do I do? All of my possible plugs are pluged in.
marsrover
  • 682 Answers
SOURCE: No signal on screen of Dell Projector 3200MP
start your laptop first then your projctor-if the problem still excit-press-control+f4 or control+f6 or control+f7
Posted on Mar 08, 2008
Myronhalo
  • 12 Answers
SOURCE: Dell 2200mp searching for signal
One problem may be that you must tell the PC to send the signal to the external monitor. Usually, if you hold down the function button and hit the F5 key you will see several options on the screen. (Other laptops use different function keys. Look for the one that shows two tv screens. You want the option which shows the laptop and the external monitor.) To advance between options, you hit the F5 button again and it moves over to the next option.
My computer needs me to lower the resolution on the laptop in order to send the signal to the projector. If you also need to do that, you can do it in Control Panel, Display, and Settings, and lower the resolution on screen number 1.
Doing both of these things should work.
Also, confirm that it is finding signals by hooking it to a DVD or video and see if it finds the signal through one of the other ports.
Posted on Mar 24, 2008
SOURCE: Dell 2300MP shows no connection after 15 min of work
Unable to view any display on the HP HP Pavilion dv9730nr Notebook PC
Posted on Apr 21, 2008
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Posted on Jun 27, 2008
SOURCE: Dell 2300MP Projector Lamp - "Orange Light"
Have you put the lamp cover back on? as I did the same and it would not power the lamp.
Posted on Nov 19, 2008
Recognize macbook connect
You may need to check the settings of your mac book that permits you to output the signal to an external display. Also you may need to purchase a display port adapter (VGA, HDMI or DVI) that is compatible with the input connector on the projector
Dec 18, 2013 | Dell 2300MP Multimedia Projector
My used DEL 2300 MP doesn't seem to be compatible with my Compaq PResario CQ60. It keeps searching for a signal? Any suggestions?
Decrease the screen resolution of your computer to the minimum possible value and check.
Probably the projector does not support the resolution of the laptop. With a lower resolution it might work.
Oct 30, 2011 | Dell 2300MP Multimedia Projector
Where can I get a schematic for dell 2300mp projector?
I found one for sale on Ebay witch seems to be in good working condition. It includes the projector itself and a carrying case. The only thing it does not include is the power cable. I have included the link below.
http://cgi.ebay.com/DELL-2300MP-2100-1-2300-ANSI-COLOR-DLP-PROJECTOR-/120705966229?pt=LH_DefaultDomain_0&hash=item1c1aa2e095#ht_3587wt_1082
Apr 01, 2011 | Dell 2300MP Multimedia Projector
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
Dell 2300mp
http://support.dell.com/support/edocs/acc/2300MP/en/index.htm
May 09, 2008 | Dell 2300MP Multimedia Projector
that's a clear indication that you have a major heating issue inside the box..the internals are apparently overheating, as it will work after cooling down, right?
Mar 07, 2008 | Dell 2300MP Multimedia Projector
Dell 2300mp projector color wheel
no there is a little difference in it. u can fix it if knows the proper settings....
there is always a setting in every thing....
Feb 07, 2008 | Dell 2300MP Multimedia Projector
157 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
