Question about Frigidaire FEF352 Electric Kitchen Range
Bottom oven element does not work but broiler element and all top electric burners work . I dont know if element is bad or digital control not working element?
  • Frigidaire Master
  • 43,501 Answers
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 25, 2010
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Cannot get oven to work
I need more info, dose the top buners work ? dose the broiler work ? Did you take a flashlight ad look over the lower cal-rod or element ? for damage get back to me on and off here all day and some nights till 9 pm
Dec 13, 2011 | Ovens
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Oven wont lite or work
You say it will not lite ? I must think you have a gas range and you most likely have a bad ignitor. If the range is electric you may have a bad bake element. You can change this easily from inside the oven. Simply unplug the range, then inside you will see the bake element on the bottom of the oven. You will find two screws holding it in. Remove the two screws and gently pull the element out of the hole. I will have two wires attached. You can remove the wires by simply pulling them off, some will be screwed to the element. You can then check the element with a voltage meter for continuity. If you have none the element is bad. Hope this helps and feel free to call if you need further help.
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Frigidaire FEF352 Electric Kitchen Range Logo
153 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
